BT.com
Wishlist
HP V201a 19.45" 1600x900 5ms VGA LED Backlit Monitor
Delivery
Standard Due date unavailable
The affordable LED business display designed for every day. Get quality presentation features at a price point that doesn't break the bank. This sleek, thin-profile LED monitor delivers 1600x900 resolution, VGA input and audio support in a space-saving 49,4 cm (19.45') diagonal screen size. Enjoy business-class brightness, contrast, and clarity in an environmentally responsible design that's easy on the wallet.
HP V201a - LED monitor - 19.45"
LED-backlit LCD monitor - 19.45"
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 3000000:1 (dynamic)
Response Time
5 ms (On/Off)
Display Position Adjustments
Tilt
46.8 cm x 19 cm x 35.53 cm
2.8 kg
English / United Kingdom
Plug and Play
1 year warranty
Display Type
Diagonal Size
19.45"
Viewable Size
19.45"
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
LED backlight
Anti-glare, Mercury free
46.8 cm x 19 cm x 35.53 cm - with stand
2.8 kg
VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable , 1 x audio cable
Plug and Play
Power Supply
Internal
19 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 46.8 cm - depth: 4.69 cm - height: 28.87 cm
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
