BT.com
Wishlist
HP V193 18.5" 1366x768 5ms VGA LED Monitor
Delivery
Standard Due date unavailable
Get quality presentation features at a price point that doesn't break the bank with the HP V193 47,0 cm (18.5") LED Backlit Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
HP v193 - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
44.14 cm x 18.9 cm x 33.86 cm
2.7 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ETL, KCC, ICES, KC, CECP, EPA, CEL Grade 1, ISC
1 year warranty
Display Type
Diagonal Size
18.5"
Viewable Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 70 kHz
Video Bandwidth
110 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, colour balance
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Anti-glare, 72% colour gamut
44.14 cm x 18.9 cm x 33.86 cm - with stand
2.7 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
Power Supply
Internal
17 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 44.14 cm - depth: 4.54 cm - height: 27.77 cm - weight: 2.4 kg , With stand - width: 44.14 cm - depth: 18.9 cm - height: 33.86 cm - weight: 2.7 kg
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
