BT.com
Wishlist
HP UPS R1500 VA G2 (220-240V)
Delivery
Standard Due date unavailable
Does your power protection strategy need to meet the same high standards as your IT hardware? HP Rack-mountable Uninterruptable Power Systems focus on the three critical areas for uninterruptable power in dense data center environments: power density, superior battery management and serviceability. Combining unity rating with more true wattage in smaller form factors, the HP Rack-mountable UPS is highly dense. The On-line On Demand hybrid technology optimizes efficiency and heat output during general operation. All HP Rack-mountable UPSs ship with the free HP Power Protector Software that incorporates Enhanced Battery Management, an exclusive patented technology that doubles battery service life, which lowers your costs. Hot-swappable batteries and intelligent automatic bypass for continuous power improve serviceability.
HPE UPS R1500 G2 - UPS - 1500 VA
UPS - rack-mountable
Output Connectors
4 x power IEC 60320 C13
Rack Size
1U
27.2 kg
Input Voltage
AC 220/230/240 V
Output Voltage
± 5%
Power Capacity
1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
Lead Acid
Run Time (Up To)
5 min at full load
48.5 cm x 58.4 cm x 4.4 cm
3 years warranty
ProLiant DL120 G6, DL160 G5p, DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL170h G6, DL180 G5, DL180 G6, DL185 G5, DL320 G6, DL360 G6, DL360 G7, DL365 G5, DL370 G6, DL380 G6, DL385 G5, DL385 G5p, DL385 G6, DL385 G7, DL585 G7, DL785 G5, DL785 G6, ML350 G6, ML370 G6, SL160z G6, SL170z G6, SL2x170z G6
Height (Rack Units)
1U
Output Connectors
Input Voltage
AC 220/230/240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
± 5%
Power Capacity
1500 VA
Dataline Surge Protection
Network - RJ-45
Output Waveform
Sinewave
Surge Suppression
Lead Acid
Voltage Provided
36 V
Run Time (Up To)
5 min at full load
Recharge Time
24 hours
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB)
Serial cable - external - 1.8 m , USB cable - external - 1.8 m
Rack Mounting Kit
Included
Equipment Protection Value
250000 US Dollars
LED display
FCC Class A certified, UL, C-Tick, BSMI, GOST, ANSI C62.41, cUL, EN 60950, GS, UL 1778, VCCI Class A ITE, CSA 22.2 No. 950, UL 60950, CISPR 22, CB, EN 50091-2, EK, CSA C22.2, EN 50091-1, FCC CFR47 Part 15
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - parts and labour - 1 year
10 °C
20 - 80%
Sound Emission
46 dB
48.5 cm
58.4 cm
4.4 cm
27.2 kg
Shipping Width
81.3 cm
Shipping Depth
68 cm
Shipping Height
29.2 cm
Shipping Weight
34.5 kg
HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL140 G3, DL160 G5, DL160 G5p, DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Special Server, DL170h G6, DL180 G5 Special Server, DL180 G6, DL180 G6 Special Server, DL185 G5 Special Server, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 Base, DL365 Entry, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL385, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML310 G3, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G5, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160z G6, SL170z G6, SL2x170z G6
Scroll to top
