Click to visit BT.com
BT.com
Wishlist
HP Ultrium 1760 LTO 800 GB / 1.6
Quicklinx: 641YWS00
Mfr#: AP826AT
HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
HPE StoreEver LTO-4 Ultrium 1760 - tape drive - LTO Ultrium - SAS
Tape drive
Recording Standard
LTO Ultrium 4
Enclosure Type
Internal
Interface Type
SAS
14.5 cm x 20.6 cm x 4.1 cm
1.45 kg
Storage Removable
LTO Ultrium - 5.25" x 1/2H
Storage Removable Capacity
800 GB (native) / 1.6 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 3, Ultrium 4
Data Transfer Rate (native)
80 MBps ( 288 GBph )
Data Transfer Rate (compressed)
160 MBps ( 576 GBph )
IBM AIX, HP-UX, Red Hat Linux, SuSe Linux, Microsoft Windows, HP Tru64 UNIX, Oracle Solaris
Microsoft Certification
Compatible with Windows 7
Manufacturer Selling Program
HP Top Value
3 years warranty
Workstation xw4550, xw4600, xw6600, xw9400, z400, z800; ProLiant DL370 G6, DL580 G5, ML110 G5, ML110 G6, ML110 G7, ML115, ML115 G1, ML115 G5, ML150 G5, ML150 G6, ML310 G4, ML310 G5, ML310 G5p, ML330 G6, ML350 G5, ML350 G6, ML370 G6; StorageWorks Rack-Mount Kit Ultrium 1760; Workstation xw8600, z600
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 4
Enclosure Type
Internal
Interface Type
SAS
14.5 cm
20.6 cm
4.1 cm
1.45 kg
Storage Removable
Recording Standard
Average Seek / Access Time
64 sec
Buffer Size
128 MB
1 x SAS - 29 pin internal SAS (SFF-8482)
Compatible Bays
1 x front accessible - 5.25" x 1/2H
Media Included Qty
4
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15, cCSAus
HP Top Value
Software Included
Drivers & Utilities
Limited warranty - parts - 3 years
10 °C
20 - 80% (non-condensing)
HP Workstation xw4550, xw4600, xw6600, xw9400, z400, z800 , HPE ProLiant DL370 G6 Base, DL370 G6 High Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, ML110 G4, ML110 G5, ML110 G6, ML110 G7, ML115, ML115 G1, ML115 G5, ML150 G3, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML150 G5 Special Server, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G3, ML310 G4, ML310 G4 1TB Storage Server, ML310 G4 2TB Storage Server, ML310 G4 3TB Storage Server, ML310 G4 584 GB SAS Storage, ML310 G4 640 GB Storage Server, ML310 G5, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G4, ML350 G5, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G4, ML370 G4 High Performance, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML370 G6 Special Server, ML570 G3, ML570 G3 High Performance, ML570 G4, ML570 G4 High Performance , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive , HPE Workstation xw8600, z600
