Click to visit BT.com
BT.com
Wishlist
HP TopShot LaserJet Pro M275 - ( printer / copier / scanner ) - colour - laser
Quicklinx: 7XCTWS00
Mfr#: CF040A#B19
Essential accessories
HP's first color MFP with TopShot scanning lets you scan, copy, and print with ease. Use HP TopShot scanning to capture images of 3D objects, and then use business apps to send directly to the web.
Experience a new, amazingly simple way to scan. Just place a 3-D object or document on top of your MFP and hit Scan--for remarkable, ready-to use digital images.
Capture images of 3D objects and scan everyday documents
- Scan images of 3D objects and post directly to the Web.5 And easily remove background via HP Scan Software
- Enjoy color multifunction performance with convenient, reliable printing and copying
- Take advantage of one-step operation and easily scan a variety of objects, documents, and images
Stay connected with innovative Web-connected printing5
- Capture images of 3D objects, then use an app to post directly to popular auction sites.5
- Use convenient Web apps to scan documents and images directly to online storage sites.5
- Stay connected and in touch by scanning business cards directly to address books.
- Access the Web directly without a PC and get a wide range of business apps.5
Stay productive--both on the go and in the office
- HP ePrint--now you can print from virtually anywhere.2
- Stay connected--share on a wireless network,3 or even print from a mobile device without using a network.4
- Now with AirPrint™. Simply print wirelessly from your iPad™, iPhone®, and iPod touch®.6
Set up quickly, stay up and running easily
- Access, store, and print with the tap of a finger, using the 3.5-in. (8.9 cm) color touchscreen display.
- Install in just a few minutes--there's no CD required with HP Smart Install.7
- Print from anywhere in the office with wireless networking3 and share resources using built-in Ethernet.
Eco-Highlights
- Save energy--HP Auto-Off Technology turns your printer Off when you don't need it.1
- Reduce energy use with Instant-on Technology.2
- Free, convenient cartridge recycling in 54 countries.
WHAT IS HP TOPSHOT SCANNING?
HP TopShot Scanning is a revolutionary technology included with the HP LaserJet Pro 200 color MFP M275. Now it's easy to quickly capture high-quality images of your documents--and even 3-D objects--for immediate use in your printed materials or on the web.
This new category of HP LaserJet MFP (multifunction product) features a camera embedded into a hinged arm that is elevated above the capture stage of the device. The camera uses a high-quality optical lens and a high-resolution sensor to capture an image of any document up to 216 by 297 mm, A4 (8.5 by 11 in, letter) or any small object. A total of six images are captured per scan or copy-- three with flashes from different angles and three in ambient light conditions with different exposure levels--producing virtually glare-free and shadow-free images. These separate shots are then automatically combined into one seamless image of exceptional quality. With HP TopShot Scanning, you'll see images similar to or better than those captured by your hand-held digital still camera and with better depth-of-focus than images from a flatbed scanner.
HP ePrint. Now print from virtually anywhere!
With HP ePrint mobile printing, there's no need to wait to print on the go. Simply send the prints you want directly to an HP ePrint enabled printer, using a smartphone, notebook, or other mobile device.¹ Stay productive and connected on the go -- print emails, photos, business materials, and more. Now you can access and print content when and where you need it.
HP ePrint Wireless Direct Printing
Easily print and share using wireless networking, and stay connected to the content you need. Plus, you can print from wireless-enabled smartphones and mobile devices -- without a network -- using HP ePrint wireless direct printing.²
Apple AirPrint™
HP ePrint-enabled printers -- now with AirPrint. Simply print wirelessly from your iPad®, iPhone®, and iPod touch®.³
1.Measured using ISO/IEC 24734, excludes first set of test documents. For more information see http://www.hp.com/go/printerclaims. Exact speed varies depending on the system configuration, software application, driver, and document complexity.
2.Requires an Internet connection to the printer. Feature works with any connected Internet- and email-capable device. Print times may vary. Some HP LaserJets may require a firmware upgrade. For a list of supported documents, and image types, see http://www.hp.com/go/eprintcenter. And for additional solutions, see http://www.hp.com/go/mobile-printing-solutions.
3.Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4 GHz routers only.
4.Mobile device must be wireless-enabled. Printer must be HP ePrint-enabled. Feature may require driver or apps, available for download at http://www.hp.com/go/eprintcenter.
5.Requires a wireless access point and an Internet connection to the printer. Services may require registration. App availability varies by country, language, and agreements. For details,
6.Supports iOS 4.2 and later devices (iPad®, iPhone® 4, iPhone® 3GS, and 3rd and 4th generation iPod touch®) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint™ and iOS 4.2 and later devices require an 802.11 "wireless network" connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple® Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
7.HP Smart Install works with Windows® only.
8.Requires an Internet connection to the printer. Services may require registration. App availability varies by country, language, and agreements. For details, http://www.hp.com/go/eprintcenter.
HP TopShot LaserJet Pro M275 MFP - multifunction printer ( colour )
Printer / copier / scanner
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser ( colour )
Monthly Duty Cycle (max)
20000 impressions
Recommended Monthly Volume
250 - 950 pages
Max Copying Speed
Up to 16 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Display
3.5"
Original Size
216 x 297 mm (max)
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP ePrint, 8 megapixel optical scan resolution, HP TopShot Scanning
AC 230 V
46.8 cm x 40.9 cm x 27 cm
13.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - colour
20000 impressions
250 - 950 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Image Enhancement Technology
HP ImageREt 2400
First Print Out Time B/W
16 sec
First Print Out Time Colour
27.5 sec
Scanning
Scan Element
CMOS
Grey Scale Depth
8 bit
Colour Depth
24 bit
Document & Media Handling
Max Original Size
216 x 297 mm
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
150 sheets
50 sheets
Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets
Speed Details
Printing : up to 16 ppm ( A4 ) - B/W , Printing : up to 4 ppm ( A4 ) - colour , Copying : up to 16 ppm ( A4 ) - B/W , Copying : up to 4 ppm ( A4 ) - colour
1 x USB 2.0 , 1 x LAN
Network Protocols
SNMP, HTTP, HTTPS
Security Protocols & Features
SSL, WEP, TLS, WPA, WPA2, TKIP, AES
Operating System Support
MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Sun Solaris 8, Sun Solaris 9, Apple Mac OS X 10.5, MS Windows 7, Ubuntu Linux 8.04 LTS, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, MS Windows Server 2008, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Ubuntu Linux 8.04.1 LTS, Ubuntu Linux 8.04.2 LTS, Debian Linux 5.0, MS Windows Server 2003 SP3 or later, Red Hat Enterprise Linux 5
Software Included
Drivers & Utilities
AC 230 V
310 Watt
Power Consumption Standby
10.8 Watt
Power Consumption Sleep
5.1 Watt
First Copy Out Time B/W
29 sec
First Copy Out Time Colour
48.5 sec
USB cable
Consumables Included
1 x Cartridge ( black ) - up to 500 pages , 1 x Cartridge ( cyan ) - up to 500 pages , 1 x Cartridge ( magenta ) - up to 500 pages , 1 x Cartridge ( yellow ) - up to 500 pages
46.8 cm
40.9 cm
27 cm
13.5 kg
Shipping Weight
17 kg
Sound Emission
50 dBA (operating)
15 °C
32.5 °C
10 - 80%
