BT.com
Wishlist
HP t630 - GX-420GI 2 GHz - 8 GB - 32 GB
Delivery
Standard 1-3 working days
Optimize your cloud-based deployments with the powerful, highly configurable, and long-lifecycle HP t630. Support your business now and in the future with powerful processing, dual Ultra HD / 4K display compatibility, and possibilities for device and network connectivity and local storage.
Designed to go above and beyond
Speed performance with an expertly engineered thin client driven by an embedded x86 quad-core system-on-a-chip. The integrated AMD Radeon graphics engine supports up to two UHD/4K displays for a fantastic media experience.
Bridge the gap with expansive connectivity
Configure a precise deployment with legacy ports for your reliable peripherals, dual-channel DDR4 system memory, wired or optional wireless or fiber connectivity, and optional local dual flash memory up to 128 GB for separate, discrete storage.
Software with all the extras, minus the extra cost
Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with exclusive HP value-added software: HP Device Manager, HP Velocity, HP True Graphics, and HP Easy Shell.
HP t630 - tower - GX-420GI 2 GHz - 8 GB - 32 GB
Thin client - tower
English / United Kingdom
1 x AMD GX-420GI 2 GHz (2.2 GHz) (Quad-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Hard Drive
1 x flash 32 GB - M.2
Graphics Controller
AMD Radeon R6E
GigE
OS Provided
Windows 10 IOT Enterprise 64-bit Edition
12 cm x 22 cm x 25.1 cm
1.52 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-420GI 2 GHz
Max Turbo Speed
2.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Unbuffered
Configuration Features
2 x 4 GB
Hard Drive
Flash - M.2
1 x 32 GB
Multi-level cell (MLC)
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R6E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Input Device
Mouse
Mouse
USB
Wake on LAN (WoL), PXE support
Slots
2 (total) / 0 (free) x SO-DIMM 260-pin , 1 M.2 Card - 2280 , 1 M.2 Card - 2242
2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 (4 front, 2 rear) , 2 x USB 3.0 (2 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x audio line-in/headphones
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
Windows 10 IOT Enterprise 64-bit Edition English
Software
Citrix ICA, Microsoft RDP, HP Universal Print Driver, HP Remote Graphics Software, Microsoft Windows Media Player 12, HP Device Manager, Citrix Receiver, VMware Horizon View, Citrix HDX, HP Velocity, Microsoft RemoteFX, Microsoft Internet Explorer 11, HP ThinUpdate, HP Easy Shell
ENERGY STAR Certified
12 cm
22 cm
25.1 cm
1.52 kg
10 °C
10 - 90% (non-condensing)
Scroll to top
