Click to visit BT.com
BT.com
Wishlist
HP t510 Flexible Thin Client, 1GB, No HDD, Windows CE 6.0 R3 Embedded
Quicklinx: 8BZVWS00
Mfr#: C4G87AT#ABU
Essential accessories
Support your virtualization environment with the HP t510 Thin Client – a significant upgrade performance with built-in energy efficiency, smart connectivity features and easy set-up guides for your PC-like multimedia needs.
HP Flexible Thin Client t510 - Eden X2 U4200 1 GHz - 2 GB - 1 GB
Thin client - tower
English / United Kingdom
1 x VIA Eden X2 U4200 / 1 GHz ( Dual-Core )
RAM
2 GB (installed) / 4 GB (max) - DDR3 SDRAM - 1066 MHz - PC3-8500
Hard Drive
Flash 1 GB
Graphics Controller
VIA ChromotionHD 2.0
Audio Output
Stereo - integrated
GigE
AC 120/230 V ( 50/60 Hz )
OS Provided
Microsoft Windows Embedded CE 6.0 R3
5.84 cm x 21.59 cm x 21.97 cm
1.49 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
3 years warranty
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Chipset Type
VIA VX900
RAM
Installed Size
2 GB / 4 GB (max)
DDR3 SDRAM
Memory Speed
1066 MHz
Memory Specification Compliance
PC3-8500
SO-DIMM 204-pin
Hard Drive
Flash
1 GB
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Mouse
Optical
USB
Wake on LAN (WoL), DHCP support, PXE support
Slots
2 SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card
6 x USB 2.0 ( 2 front, 2 rear ) , 1 x serial , 1 x parallel , 1 x VGA ( with adapter ) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x microphone , 1 x DVI-I , 1 x DVI-D
DVI-VGA adapter
Theft/Intrusion Protection
RoHS
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
OS Certified
Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Microsoft Windows Server 2000 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
Software
Microsoft RDP 6.0, Symantec Endpoint Protection, Microsoft Internet Explorer 6.0 for Windows CE 6.0, Citrix ICA 10.x, File Based Write Filter, Enhanced Write Filter, VMware View 4.5, HP TeemTalk Emulator, LogOn Manager
EPEAT Compliant
EPEAT Gold
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years
5.84 cm
21.59 cm
21.97 cm
1.49 kg
10 °C
10 - 90% (non-condensing)
