BT.com
Wishlist
HP Stream Pro 11 G3 Celeron N3060 / 1.6 GHz - Win 10 Home
Delivery
Standard Due date unavailable
Upgrade classroom learning with the thin, light, and powerful HP Stream 11 Pro. Take learning to another level, while maximizing collaboration using stable and reliable connectivity.
HP Stream Pro 11 G3 - 11.6" - Celeron N3060 - 4 GB RAM - 64 GB SSD - UK
Notebook
Operating System
Win 10 Home 64-bit - English
Intel Celeron N3060 / 1.6 GHz (2.48 GHz) / 2 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
64 GB - eMMC SSD
Optical Drive
No optical drive
Display
11.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 400
Input Device
ClickPad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
30 cm x 20.56 cm x 1.8 cm
1.17 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.48 GHz
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800 - 1600 MHz
Storage
Main Storage
64 GB SSD - (eMMC)
Display
11.6" - TN
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - VGA
Video Resolutions
640 x 480
Frame Rate
24 frames per second
Camera Features
Noise reduction
Sound
Stereo speakers, microphone
Codec
Realtek ALC3227
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Multi-touch clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
2-cell lithium polymer
37.69 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB 2.0 , USB 3.0 , HDMI
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Support Assistant, HP ePrint, McAfee LiveSafe, McAfee Checkbox, HP JumpStart
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.17 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Scroll to top
