BT.com
Wishlist
HP StorageWorks 1/8 G2 Tape Autoloader LTO-4
Delivery
Standard Due date unavailable
Designed for basic data protection, the HP StorageWorks 1/8 G2 Tape Autoloader is the ideal entry-level automated backup solution that combines exceptional storage density and tape library features into the compact form of a tape autoloader. With compressed capacity (2:1) using HP StorageWorks LTO-4 Ultrium 1760 Tape Drive technology, the 1/8 G2 Tape Autoloader will provide cost-effective, easy-to-install unattended backup. No more struggling to remember to change tapes or start backup programs. Reliable backup equals peace of mind.
HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 1760 - tape autoloader - LTO Ultrium - SAS
Tape autoloader
Recording Standard
LTO Ultrium 4
Enclosure Type
External - 1U
Interface Type
SAS
Total Storage Capacity
6.4 TB (native) / 12.8 TB (compressed)
Removable Media Capacity
8
Average Media Exchange Time
34 sec
Supported Tape Drives
LTO Ultrium 4
Key Features
Barcode reader
48.2 cm x 80.9 cm x 4.4 cm
11.5 kg
Storage Removable
LTO Ultrium
Storage Removable Capacity
800 GB (native) / 1.6 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 3, Ultrium 4
Data Transfer Rate (native)
80 MBps ( 288 GBph )
Data Transfer Rate (compressed)
160 MBps ( 576 GBph )
AC 120/230 V ( 50/60 Hz )
1 year warranty
ProLiant DL160 G5, DL160se G6, DL165 G5, DL165 G6, DL180 G5, DL185 G5, DL320 G5p, DL320 G6, DL360 G5, DL365 G5, DL380 G6, DL380 G7, DL385 G5, DL385 G5p, DL385 G6, DL385 G7, DL585 G6, DL785 G5, ML115 G5, ML310 G5, ML330 G6, ML370 G5
Tape autoloader - LTO Ultrium
Recording Standard
LTO Ultrium 4
Enclosure Type
External - 1U
Interface Type
SAS
8
34 sec
LTO Ultrium 4
Key Features
Barcode reader
Built-in Devices
Status LCD, led panel
48.2 cm
80.9 cm
4.4 cm
11.5 kg
Storage Removable
LTO Ultrium
Recording Standard
Average Seek / Access Time
64 sec
Buffer Size
128 MB
1 x management - RJ-45 , 1 x USB ( management ) , 1 x SAS - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
1 x Serial ATA / SAS cable , 1 x network cable
Rack Mounting Kit
Optional
MTBF
100,000 hour(s)
MSBF
1,000,000
Power supply
Software Included
Drivers & Utilities, HP StorageWorks Data Protector Express Single Server
Limited warranty - parts - 1 year - response time: next business day
10 °C
35 °C
20 - 80%
HPE ProLiant DL160 G5, DL160se G6, DL165 G5 Special Server, DL165 G6, DL180 G5 Special Server, DL185 G5 Special Server, DL320 G5p, DL320 G6, DL360 G5 Performance, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL380 G6, DL380 G6 Entry, DL380 G7, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G6, DL585 G6 Base, DL785 G5, ML115 G5, ML310 G5, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML370 G5
Scroll to top
