BT.com
Wishlist
HP Spectre 13 Pro and Bang Olufsen A1 Speaker Bundle
Bundles
Exclusive
New
Limited Time Offer
Limited time offer!
Delivery
Standard Due date unavailable
HP Spectre 13 Pro
World-class design combines with rich features to revolutionize computing. The incredibly thin HP Spectre Pro 13 delivers the power and performance you need for your workday with an irresistible style all its own.
A flair for the dramatic
Work in luxury using this incredibly thin and light laptop that suits your sophisticated style with its remarkable internal piston hinge design and hyperbaric cooling system that streamlines the profile of the HP Spectre Pro 13.
No compromise performer
Get the substance and style you crave. This elegant PC uses powerful Intel® Core™ i5/i7[2] processors, has robust PCIe storage options, and USB-C™ ports for easy connections.
Delight your senses
Treat yourself to a more refined collaboration experience with an FHD IPS Corning® Gorilla® Glass display, exquisite Audio by Bang & Olufsen, and a premium backlit full size keyboard that looks as good as it feels.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, collaboration-ready HP Spectre Pro 13.
Performance to get the job done
Work, surf, and connect with colleagues with the performance of a 6th Gen Intel® Core™ i5/i7 processor, PCIe SSDs, and long battery life that lets you work for hours.
Dramatic design
Delight your senses with the alluring HP Spectre Pro 13. Refined dark ash and copper color surfaces surround the full-sized backlit keyboard. A smooth glass clickpad provides ample space for gestures and precision navigation.
Easy connections
Quickly connect to your tablet, phone, or fitness tracker. The three USB-C™ charging ports allow for hassle-free charging of mobile devices and the HDMI adapter allows fast connections to monitors and projectors.
Cut the clutter
Connect quickly using the optional Thunderbolt™ dock with support for dual 4K monitors.
Connect and collaborate in style
Collaborate effectively using Audio by Bang & Olufsen, HP Noise Cancellation, HP Audio Boost, and an HD webcam.
Cloud-based IT management made simple
HP Touchpoint Manager3 offers customers simple, useful tools and services from a single cloud-based solution for managing data, security, and a wide array of third party devices.
Valuable support at your service
Get hassle-free technical support with Helpdesk by HP Care. Rely on cost-effective expertise that’s available 24x7, covering multiple brands, devices and operating systems.
Bang & Olufsen Beoplay A1
Life is an adventure.
Some epic. Some everyday.
The ultra-portable Bluetooth speaker that will travel with you anywhere and bring more sound and more bass into your life - wherever it's happening that moment.
More sound. More bass.
Packing a punch well beyond its weight and size, Beoplay A1 has ambient True 360 sound – so the sound dispersion is great wherever you put it. And with a peak power of 2x140 W you won’t have to huddle round it to enjoy your music.
Even the heaviest beats are easy to carry.
Beoplay A1 is small enough to sit in the palm of your hand, it weighs only 600g, and because of its shape (with no protruding buttons or legs) it is easy to store in your bag or slip into a pocket. So you can take it anywhere you go and enjoy Bang & Olufsen Signature Sound when you get there.
Form and function in harmony.
The rounded aluminium grill is both a thing of beauty and of strength, and together with the double-moulded polymer base, it forms a strong protective shell for the components within. Cool aluminium. Warm polymer. Soft leather. Simply put, Beoplay A1 is amazing to touch and hold in your hand.
Play on.
With up to 24 hours* of battery life, Beoplay A1 will still be playing long after most competitors have gone silent. And when you do eventually need to charge it, Beoplay A1’s smart charging system will adapt charging speed to match the capacity of the USB charger you are using – so it will quickly be ready for the next adventure.
HP Spectre Pro 13 G1 - 13.3" - Core i5 6200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
8 GB LPDDR3
Storage
256 GB - M.2 SSD NVMe
Optical Drive
No optical drive
Display
13.3" WLED 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.5 cm x 22.94 cm x 1.04 cm
1.16 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2) SATA 6Gb/s - NVM Express (NVMe)
Display
13.3"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Ultra Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Camera Features
HP TrueVision FHD
Sound
Stereo speakers, stereo microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad
Backlight
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
38 Wh
AC Adapter
Input
Output
45 Watt
Connections & Expansion
USB-C , 2 x USB-C/Thunderbolt 3 , Headphone/microphone combo jack
Software
Software Included
Cyberlink PowerDVD, CyberLink Youcam, Adobe Shockwave Player, HP ePrint, Absolute Data Protect, Foxit PhantomPDF Express, Intel Wireless Display, HP Wireless Hotspot, HP Touchpoint Manager, MS BitLocker, CyberLink Power Media Player 12
Security
HP Audio Boost
Power adapter
Localization
1.16 kg
ENERGY STAR Certified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Scroll to top
