BT.com
Wishlist
HP Slice ODD Module
Delivery
Standard 3-5 working days
Hardware compatibility
HP Elite Slice and HP Elite Slice for Meeting Rooms
Quickly and easily back up files and access content from your choice of optical media with the HP ODD Module that snaps into your HP Elite Slice solution for a simple unified footprint.
No cabling or screws required
Snap the Module beneath your HP Elite Slice with a sturdy USB-type connection that provides a simple and clean solution with no messy cables.
Multi ODD media compatible
Support legacy content on CD or DVDs, or use this module with the HP Audio Module as a beautiful media player.
Lock it down
Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your Module and HP Elite Slice together with one cable lock.
Mix and match
Create a unique solution for each of your employees when you use the HP ODD Module stacked with your HP Elite Slice and any of the other HP Elite Slice accessories.
HP ODD Module - DVD-ROM drive - external
16.5 cm x 16.5 cm x 2.45 cm
452 g
Optical Storage
DVD-ROM
1 year warranty
HP 20, 22, 24; Elite Slice, Slice for Meeting Rooms; ENVY 750; ENVY Curved 34; Pavilion 24, 27
16.5 cm
16.5 cm
2.45 cm
452 g
Optical Storage
DVD-ROM
Limited warranty - 1 year
HP 20-c001na, 20-c005ns, 20-c006la, 20-c010nd, 20-c011np, 20-c011ns, 20-c012nf, 20-c015na, 20-c015nl, 20-c016nl, 20-c019la, 20-c020nf, 20-c024nl, 22-b000ny, 22-b003la, 22-b005nf, 22-b005np, 22-b009la, 22-b016ns, 22-b017la, 22-b022no, 22-b023ns, 22-b024nf, 22-B026ns, 22-b030nj, 22-b031ur, 22-b041ne, 22-b065na, 22-b308la, 24-g003ns, 24-g004na, 24-g006la, 24-g006na, 24-g008ns , HP Elite Slice, Slice for Meeting Rooms , HP ENVY 750-537cb, 750-545xt , HP ENVY Curved 34-b000ng, 34-b004la, 34-b071ns, 34-b080nl , HP Pavilion 24-b008la, 27-a002la
Scroll to top
