BT.com
Wishlist
HP Scanjet Professional 1000 mobile scanner
Delivery
Standard Due date unavailable
HP Scanjet Professional 1000 Mobile Scanner
Scan documents on the spot, wherever you are--in the office, in the field or on the go--with the HP compact, portable scanner. Organize contracts, forms, receipts and business cards on your PC instead of on your desk or in your briefcase.
Digitize documents nearly anywhere and on the go.
  • Capture documents on the spot--in the office, at your customer's site and even on the road.
  • Carry and use the scanner almost anywhere--it's lightweight, portable and compact.
  • Protect and store the scanner in the included sturdy carrying case.
  • Power the mobile scanner via your PC's Hi-Speed USB 2.0 port--no batteries or AC adapter needed.
Easily scan and organize your digital information.
  • Scan with the touch of a button or scan directly from the application you're working in.
  • Scan in different file formats--PDF, TIFF, JPEG, Microsoft Word--and save disk space with smaller file sizes.
  • Archive files with Nuance PaperPort, and convert scans into editable files with Nuance OmniPage.[1]
  • Scan and organize business cards and embossed cards, using NewSoft Presto! BizCard Reader software.[1]
Quickly scan a variety of two-sided documents.
Save energy with Instant-on scanning technology Reduce clutter and waste--scan and share documents digitally Reduce packaging waste, contains innovative, reusable tote made from recycled plastic bottles
ENERGY STAR® Qualified
http://www.hp.com/ecosolutions
  • Scan a variety of paper sizes, from business cards to long forms.
  • Scan at up to 5 ppm or two-sided in a single pass at up to 8 ipm, using the manual feed slot.
  • Capture all the detail and fine print at up to 600 dpi scanning resolution.
HP ScanJet 1000 Professional Mobile Scanner - sheetfed scanner - desktop - USB 2.0
Sheetfed scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 864 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Size
216 mm x 864 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Duty Cycle
100 scans per day
Microsoft Windows 2000 / XP, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
29 cm x 5 cm x 7.5 cm
0.66 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 864 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Duty Cycle
100 scans per day
Media Handling
Max Document Size
216 mm x 864 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 864 mm
Manual
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
29 cm
5 cm
7.5 cm
0.66 kg
Shipping Width
34.5 cm
Shipping Depth
15.5 cm
Shipping Height
8.7 cm
Shipping Weight
1.2 kg
10 - 80%
Scroll to top
