BT.com
Wishlist
HP Scanjet Pro 3000 S2 Sheetfeed Scanner
Delivery
Standard Due date unavailable
Turn the page on time-consuming, manual document handling. This intelligent scanner is easy to use and makes any office more efficient. Get clear, crisp digital documents every time – and cut your power consumption with this energy-efficient device.
HP Scanjet Pro 3000 s2 - sheetfed scanner - desktop - USB 2.0
Sheetfed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
215.9 x 864 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
215.9 mm x 864 mm
Automatic Duplexing
Document Feeder Type
Automatic
Duty Cycle
1000 scans per day
Apple MacOS X 10.7 Lion, Apple MacOS X 10.6.8, Microsoft Windows Vista / XP / 7 / 8, Apple MacOS X 10.8
28.5 cm x 16.1 cm x 16.4 cm
2.3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
215.9 x 864 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Scan Element Type
Bulb / Light Source Type
LED
Control Panel Buttons Functions
Scan, cancel
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - 300 dpi (front) / 300 dpi (back) , 40 ipm - duplex - 300 dpi (front) / 300 dpi (back)
Scanner Features
Ultrasonic Multi Feed Detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 864 mm
Supported Document Size Details
ADF - up to 215.9 x 864 mm
Automatic
USB 2.0
1 x USB cable
GOST, CISPR 24, EN55022, SASO, EN55024, CISPR 22, EMC, RoHS, IEC 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 61000-3-2:2006, EN 61000-3-3:2008, EN 60950-1:2006
ENERGY STAR Certified
Power Consumption Operational (Standby)
11.6 Watt (5.9 Watt)
Software Included
Readiris Pro 14, HP Easy Scan, Nuance PaperPort 14, Cardiris Pro 5
System Requirements Details
Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 177 MB , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 177 MB
28.5 cm
16.1 cm
16.4 cm
2.3 kg
Shipping Width
38 cm
Shipping Depth
28.5 cm
Shipping Height
21.6 cm
Shipping Weight
4 kg
10 °C
35 °C
15 - 80%
Scroll to top
