BT.com
Wishlist
HP ScanJet N9120 Flatbed Scanner
Delivery
Standard Due date unavailable
HP Scanjet N9120 Document Flatbed Scanner
Capture single or two-sided documents up to A3-size with this fast, robust departmental scanner. Scan at up to 100 ipm with 200 page ADF and ultrasonic double-feed detection. Use HP Smart Document Scan Software or integrate into existing systems.
HP ScanJet N9120 Document Flatbed Scanner - flatbed scanner - USB 2.0
Flatbed scanner
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
300 x 864 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
300 mm x 864 mm
Supported Document Type
Plain paper, card scanner
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
5000 scans per day
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions)
Microsoft Certification
Certified for Windows Vista
69.2 cm x 55.8 cm x 33.8 cm
37 kg
Environmental Standards
ENERGY STAR Qualified
Flatbed scanner
Interface Type
USB 2.0
300 x 864 mm
Scanner
Input Type
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
CCD
Bulb / Light Source Type
Control Panel Buttons Functions
Scan, copy, power save, cancel
Duty Cycle
5000 scans per day
Scanner Speed Details
50 ppm - Letter , 40 ppm - black & white - 200 dpi , 40 ppm - colour - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
300 mm x 864 mm
Supported Document Size Details
ADF - up to 300 x 864 mm
Automatic
200 sheets
USB 2.0 - Type B
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Internal power supply
Software Included
Drivers & Utilities, Readiris Pro, Kofax VirtualReScan Professional
Additional Requirements
CD-ROM, SVGA monitor
System Requirements Details
Windows 2000/XP - 500 MHz - RAM 256 MB - HD 300 MB , Windows Vista - 800 MHz - RAM 512 MB - HD 300 MB
69.2 cm
55.8 cm
33.8 cm
37 kg
10 °C
35 °C
15 - 80%
Scroll to top
