BT.com
Wishlist
HP Scanjet Enterprise Flow 7000 S2 Sheet-feed Scanner
Delivery
Standard Due date unavailable
Enhance performance and streamline workflow, using a fast, reliable scanner. The compact, efficient footprint of this PC-connected device saves energy, while producing consistent, high-quality images in black-and-white, greyscale or colour.
HP ScanJet Enterprise 7000 s2 Sheet-feed Scanner - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
LED
Max Supported Document Size
216 x 3098 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
45 ppm (mono) / 45 ppm (colour)
Max Document Size
216 mm x 3098 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner, plastic card, labels
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
31 cm x 18.1 cm x 18 cm
5.35 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
216 x 3098 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
45 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
90 ipm - duplex black & white (back) , 90 ipm - duplex - colour - A4 / Letter , 45 ppm - duplex black & white (back) , 45 ppm - duplex - colour - A4 / Letter
Scanner Features
Color Dropout, Blank Page Removal, Ultrasonic Multi Feed Detection, 2 line x 16 character LCD
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3098 mm
Supported Document Size Details
ADF - up to 216 x 3098 mm
Automatic
50 sheets
USB 2.0 - Type B
Cleaning cloth
1 x USB cable
C-Tick, BSMI, CISPR 22 Class A, GOST, CISPR 22 Class B, CISPR 24, cUL, SASO, EN 61000-3-3, CCC, EMC, FCC, UL 60950-1 Second Edition, KCC, CSA C22.2 No. 60950-1 Second Edition, IEC 60950-1 Second Edition, NRTL
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
42 Watt (1.822 Watt)
Software Included
Readiris Pro, Kofax VirtualReScan Professional, Nuance PaperPort, HP Smart Document Scan Software, Cardiris Pro
System Requirements Details
Windows 7/Vista - 2 GHz - RAM 2 GB - HD 150 MB (USB 2.0) , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 150 MB (USB 2.0)
31 cm
18.1 cm
18 cm
5.35 kg
Shipping Width
39.9 cm
Shipping Depth
30.3 cm
Shipping Height
27.8 cm
Shipping Weight
7.4 kg
Limited warranty - 1 year , Technical support - phone consulting - 1 year - response time: 24 hours
10 °C
35 °C
15 - 80% (non-condensing)
Scroll to top
