BT.com
Wishlist
HP ScanJet Enterprise Flow 5000 s3 Sheet-feed Scanner
Delivery
Standard Due date unavailable
Abandon paper-based workflows. Advance office efficiency with fast, intuitive scanning that turns hard copies into useful digital data. Rely on clear, legible results from a compact scanner designed to enhance collaboration.
HP ScanJet Enterprise Flow 5000 s3 Sheet-feed Scanner - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
LED
Additional Functions
Scan to cloud
Max Supported Document Size
216 x 3098 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 3098 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner, plastic card, labels, envelope
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
4000 scans per day
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3 or later, Windows 8
31 cm x 18.24 cm x 18.38 cm
4.82 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scan to cloud
216 x 3098 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Scan Element Type
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
30 ppm - black & white - 300 dpi , 30 ppm - colour - 300 dpi , 60 ipm - black & white - 300 dpi , 60 ipm - colour - 300 dpi
Scanner Features
Automatic Separation, Automatic Image Orientation, automatic page size detection, Auto Crop, auto power off, Auto Straighten, Ultrasonic Multi Feed Detection, HP EveryPage
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3098 mm
Supported Document Size Details
ADF - up to 216 x 3098 mm
Automatic
50 sheets
USB 2.0 - Type B
Cleaning cloth
1 x USB cable
CSA, CISPR 24, SASO, CISPR 22, EMC, IEC 60950-1, UL 60950-1 Second Edition, EN 61000-3-2:2006, EN 61000-3-3:2008, EN 60950-1:2006, EAC, EN55022:2010
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
26.4 Watt
Software Included
Readiris Pro, Nuance PaperPort, HP Smart Document Scan Software, Cardiris Pro
System Requirements Details
Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 177 MB (USB 2.0) , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 177 MB (USB 2.0)
31 cm
18.24 cm
18.38 cm
4.82 kg
Shipping Width
39.5 cm
Shipping Depth
33.2 cm
Shipping Height
29.8 cm
Shipping Weight
7.3 kg
10 °C
35 °C
15 - 80% (non-condensing)
Scroll to top
