BT.com
Wishlist
HP Scanjet 5590
HP Scanjet 5590
Delivery
Standard Due date unavailable
HP Scanjet 5590 Digital Flatbed Scanner
High speed, unattended document scanning with duplex automatic document feeder (ADF). Get the job done quickly with scan-to-PDF simplicity and bundled NewSoft Presto! PageManager document management software. ISIS compliance included.
HP ScanJet 5590 Digital Flatbed Scanner - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 297 mm
English / United Kingdom
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
Interpolated Resolution
999999 dpi x 999999 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Transparencies, plain paper, slides, film
Document Feeder Type
Manual, automatic
Document Storage Capacity
50 sheets
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.1.5, Apple MacOS X 10.2 or later
Microsoft Certification
Certified for Windows Vista
48.8 cm x 34 cm x 16.2 cm
5.7 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
Control Panel Buttons Functions
Scan, copy, email, Scan-to-Web, power save, cancel, Scan-to-PDF
Scanner Speed Details
28 sec/scan - photo - colour - 10x15cm , 31 sec/scan - black & white , 48 sec/scan - OCR - A4 , 7 sec/scan - preview
TWAIN
Media Handling
Max Document Size
216 mm x 297 mm
Manual, automatic
50 sheets
USB 2.0 - Type B
Automatic document feeder, transparency adaptor
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
UL, GOST, EN 60950, PCBC, EMC
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
36 Watt
Software Included
Drivers & Utilities, Presto! PageManager, HP Memories Disc Creator, HP Instant Share, I.R.I.S. OCR
Additional Requirements
CD-ROM, SVGA monitor, USB port
System Requirements Details
Windows 98/98SE/2000/ME/XP - Pentium II RAM 64 MB - HD 225 MB , MacOS X 10.1.5 or later - RAM 128 MB - HD 240 MB
48.8 cm
34 cm
16.2 cm
5.7 kg
Limited warranty - 1 year
5 °C
5 - 90%
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Nice scanner, rubbish software!
Reviewed by Anonymous on 27/11/2009
We have a number of these in use at our company.
The scanner itself is the usual quality from HP that one would expect. The software on the other hand is really not worth installing as it is hopeless. Our experience shows that Omnipage software by Nuance works well with this device.
2* HP Scanjet
Reviewed by Ed Sedgwic on 12/11/2007
The software that goes with this is way too complex. The hardware itself is fine but the hassle factor is huge. I wish I had bought something else.
2* Unstable software
Reviewed by Paul Williamson on 31/03/2007
I had an older version of this scanner which was, like other HP products up to then, fast, efficient and as solid as a rock. It got involved in a lightning strike so had to be replaced. This HP5590 is by comparison a waste of time, largely because of the software which has so many fgeatures it can't stand up. I'm constantly battling to stop it automatically doing things I don't want. I'm faily experienced at all this but the way this keeps failing in different ways and then works and then doesn't again has wasted hours. It has been difficult to find these features at this price until now when there is now competition. Any other scanner must be better than this. It's the software that's the problem but upgrades and re-installs fail to fix the unreliability.
1* HP ScanJet 5590 software problems
Reviewed by Anonymous on 06/12/2007
I purchased one of these three months ago and the scanning and copying process hangs most of the time (at least 75% of the time, sometimes worse). Even after two software reinstalls it continues to fail. Base unit was replaced, but same problems occured.
Scroll to top
