BT.com
Wishlist
HP S/Works D2D4004i Backup System
Delivery
Standard Due date unavailable
Has unpredictable data growth resulted in management complexity and risk? HP StoreOnce Backup systems with StoreOnce Catalyst software provide a consistent, high-performance scale-out backup architecture that spans the entire enterprise and Federated Catalyst that can reduce management in large environments. You can reduce the amount of backup data you need to store by 95% and choose between powerful dedicated appliances for larger offices and data centers, and flexible virtual appliances for smaller and remote offices. Industry leading backup and restore speeds mean that you can meet shrinking backup windows and recovery SLAs. Plus, with HP StoreOnce as the industry's only federated deduplication technology, you can dedupe anywhere and control the movement of dehydrated data across the enterprise using your backup application. Seamlessly integrating with your current backup applications, StoreOnce Backup provides flexible integration for SAN, Ethernet and virtualized environments.
HPE StorageWorks D2D4004i Backup System - NAS server - 4.5 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
4.5 TB
44.8 cm x 69.9 cm x 8.8 cm
25.9 kg
Storage Controller
SATA RAID 6
Hard Drive
6 x 750 GB
Network adapter 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
1 year warranty
ProLiant DL160se G6, DL165 G5, DL180 G5, DL185 G5, DL320 G5p, DL360 G5, DL360 G7, DL365 G5, DL370 G6, DL380 G7, DL385 G5, DL385 G5p, DL385 G7, DL785 G5, ML115 G5, ML310 G5, ML350 G5, ML350 G6, ML370 G5, ML370 G6
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
4.5 TB
44.8 cm
69.9 cm
8.8 cm
25.9 kg
Storage Controller
SATA
RAID Level
RAID 6
Hard Drive
HDD
6 x 750 GB
Spindle Speed
7200 rpm
Network adapter
100Mb LAN, GigE
2 x network cable - 3 m , 2 x power cable
X internal power supply
Power Provided
750 Watt
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
10 °C
35 °C
10 - 90%
HPE ProLiant DL160se G6, DL165 G5 Special Server, DL180 G5 Special Server, DL185 G5 Special Server, DL320 G5p, DL360 G5 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 G5 Base, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G5 Entry, DL385 G5p Base, DL385 G5p High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL785 G5, ML115 G5, ML310 G5, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G5, ML370 G6, ML370 G6 Base, ML370 G6 Entry
Scroll to top
