BT.com
Wishlist
HP Replacement Laptop Keyboard
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
This keyboard can be used as a replacement for your original laptop keyboard, if the original is damaged or broken. The keyboards are very easy to fit, with no soldering required.
HP - keyboard - UK
Keyboard
Layout
Pointing stick
ProBook 650 G1 (15.6 in)
Keyboard
Input Device
Layout
Pointing stick
1 x keyboard cable , 1 x pointing stick cable
RoHS
HP ProBook 650 G1 (15.6 in)
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: BV7Y 035420
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£4.69
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
