Click to visit BT.com
BT.com
Wishlist
HP Quick Relase Bracket for TFT
HP LCD Monitor Quick Release Mount
Quicklinx: 4RPNWS00
Mfr#: EM870AT
Accessory Type: Camera tripod
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£24.49
A secure and easy-to-use mounting solution for your VESA-compliant HP flat panel monitors, thin clients and other HP desktop products. Attach to any a compatible stand, bracket or wall mount and make the most of your workspace.
HP Quick Release - mounting kit
Mounting kit
13.2 cm x 1.7 cm x 16 cm
370 g
Recommended Use
Flat panel
Flat Panel Mount Interface
100 x 100 mm
Max Load Weight
10.9 kg
1 year warranty
Compaq S1922, S2021; HP 2310, 6300, Elite 8300, LA22, LE19, LE1911, s1922, S1932, S1933, S2031, S2032, S2231, S2331, t5325, t5545, t5550, t5565, t5570, t5740, ZR30; EliteOne 800 G1; Flexible Thin Client t520, t610; ProOne 400 G2, 600 G1; Thin Client t5730; HPE t5145, t5540; Compaq Thin Client t5735
13.2 cm
1.7 cm
16 cm
370 g
AV Furniture
Mounting kit
Recommended Use
Flat panel
100 x 100 mm
Max Load Weight
10.9 kg
Limited warranty - 1 year
Compaq S1922, S2021 , HP 2310ti, gt7720, gt7725, L1506, L1506s, L1706, L1706v, L1710, L1740, L1750, L1906, L1908w, L1908wm, L1910, L1940T, L1945w, L1945wv, L1950, L1950g, L2045w, L2208w, L2245w, L2245wg, L2445w, LA2205wg, LE1851w, LE1901w, LE1901wm, LE2001w, LE2001wm, LE2201w, S1932, S1933, S2031, S2032, S2231a, S2331a, st5548, st5738, t5325, t5545, t5550, t5565, t5570, t5630, t5630w, t5740, t5740e, v185ws, vc4820T, vc4825T, w17e, ZR30w , HP EliteOne 800 G1 , HP Flexible Thin Client t520, t610, t610 PLUS , HP ProOne 400 G2, 600 G1 , HP Compaq 6005 Pro (ultra-slim desktop), 6300 Pro PC, Elite 8300 PC, L2105tm, LA1751g, LA1905wg, LA1951G, LA2205wg, LA22f, LA2405wg, LE1711, LE1911, LE19f, s1922 , HP Compaq Business Desktop dx2009 , HP Compaq Thin Client gt7720, gt7725, t5135, t5530, t5630, t5630w, t5720, t5725, t5730, t5730w , HPE t5145, t5540 , HPE Compaq Thin Client t5735
HP Quick Relase Bracket for TFT Bundle deal on HP Quick Relase Bracket for TFT
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£28.58
saving £1.39
Brand: HP
Price Range Inc VAT: 0 - 50
