BT.com
Wishlist
HP Quick Relase Bracket for TFT
£37.33
28 in stock
£37.33
Add to wishlist
Delivery
Standard 3-5 working days
HP LCD Monitor Quick Release Mount
A secure and easy-to-use mounting solution for your VESA-compliant HP flat panel monitors, thin clients and other HP desktop products. Attach to any a compatible stand, bracket or wall mount and make the most of your workspace.
HP Quick Release - mounting kit
Mounting kit
13.2 cm x 1.7 cm x 16 cm
370 g
Recommended Use
Flat panel
Flat Panel Mount Interface
100 x 100 mm
Max Load Weight
10.9 kg
1 year warranty
Compaq S1921; HP 260 G2, 6300, Elite 8300, L2105, S1932, S1933, S2032, t5545, t5550, t5565, t5570, v185, v216; EliteOne 800 G1; Flexible Thin Client t520, t610; ProOne 400 G2, 600 G1; Smart Zero Client t410; Thin Client t5730; HPE t5145, t5540; Compaq Thin Client t5735; Flexible Thin Client t510
13.2 cm
1.7 cm
16 cm
370 g
AV Furniture
Mounting kit
Recommended Use
Flat panel
100 x 100 mm
Max Load Weight
10.9 kg
Limited warranty - 1 year
Compaq LA2405wg, S1921, S1922, S2021 , HP 2310ti, 260 G2, gt7720, gt7725, L1506, L1506s, L1706, L1706v, L1710, L1740, L1750, L1906, L1908w, L1908wm, L1910, L1940T, L1945w, L1945wv, L1950, L1950g, L2045w, L2105tm Touchscreen, L2208w, L2245w, L2245wg, L2445w, LA1905wg, LA2205wg, LE1851w, LE1901w, LE1901wm, LE2001w, LE2001wm, LE2201w, S1932, S1933, S2021, S2031, S2032, S2231a, S2331a, st5548, st5738, st5742, st5747, st5748, t5325, t5545, t5550, t5565, t5570, t5630, t5630w, t5740, t5740e, t5745, v185w, v185ws, v216w, vc4820T, vc4825T, w17e, ZR30w , HP EliteOne 800 G1 , HP Flexible Thin Client t520, t610, t610 PLUS , HP ProOne 400 G2, 600 G1 , HP Smart Zero Client t410 , HP Compaq 6005 Pro (ultra-slim desktop), 6300 Pro PC, Elite 8300 PC, L2105tm, LA1751g, LA1905wg, LA1951G, LA2205wg, LA22f, LA2405wg, LE1711, LE1911, LE19f, s1922, S2021 , HP Compaq Business Desktop dx2009 , HP Compaq Thin Client gt7720, gt7725, t5135, t5530, t5630, t5630w, t5720, t5725, t5730, t5730w , HPE t5145, t5540 , HPE Compaq Thin Client t5735 , HPE Flexible Thin Client t510
Scroll to top
