BT.com
Wishlist
HP ProLiant ML110 G7 E3-1220 NHP SATA UK Svr/TV
Delivery
Standard Due date unavailable
The HP ProLiant ML110 G7 is the perfect first server for a growing business. It provides an affordable, efficient, functional solution to small/medium businesses that are budget-conscious and have basic or no in-house IT resources. With proven ProLiant reliability, support for the latest Intel Xeon , Core i3, Pentium and Celeron processors, an optional redundant power supply (RPS), and two NICs, the ML110 G7 provides the ideal solution for the expanding business. A mix of PCI-Express slots, DIMM slots, drive bays, and server options delivers the expandability needed. Integrated iLO3 remote management drives down the operational costs by reducing the number of physical visits. An HP Smart Start CD enhances the installation process. Optional TPM provides an additional level of security, and a high efficiency power supply is available to further reduce power consumption.
HPE ProLiant ML110 G7 - micro tower - Xeon E3-1220 3.1 GHz - 2 GB - 250 GB
Server - micro tower
Height (Rack Units)
4U
United Kingdom
Server Scalability
1-way
1 x Intel Xeon E3-1220 / 3.1 GHz (3.4 GHz) (Quad-Core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
2 GB (installed) / 16 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s) (Smart Array B110i)
Hard Drive
1 x 250 GB - SATA 3Gb/s
GigE
17.5 cm x 47.3 cm x 36.7 cm
26.8 kg
1 year warranty - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower - 4U
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
2
United Kingdom
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
2 GB / 16 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Unbuffered
Hard Drive
HDD
1 x 250 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Storage Controller Name
Smart Array B110i
RAID Level
RAID 0, RAID 1, RAID 10
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Integrated
Interface (Bus) Type
PCI Express 2.0 x1
Ethernet Controller
HP NC112i
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Lights-Out 3
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 801.1p
Bays
2 (total) / 2 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" LFF
Slots
2 (total) / 2 (free) x PCIe x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe x4 - half-length, full-height (x1 mode) , 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin
1 x display / video , 1 x serial , 8 x USB (4 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 1 x HP iLO
System password, power-on password
FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438, ACPI 3.0b
Power supply
Nominal Voltage
Power Provided
350 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
Limited warranty - parts and labour - 1 year - on-site
17.5 cm
47.3 cm
36.7 cm
26.8 kg
10 °C
35 °C
10 - 90% (non-condensing)
Sound Emission
24.4 dBA
Scroll to top
