Click to visit BT.com
BT.com
Wishlist
HP PROLIANT DL360P G8 E5-2620
Quicklinx: 82TBWS00
Mfr#: 670640-425
Is your data center space constrained yet performance driven? The HP ProLiant DL360p Gen8 Server provides enterprise class 2-socket performance and efficiency in a space saving 1U size. With Gen8 enhanced serviceability and configuration flexibility, it is ideal for general purpose applications such as file/print, web, dynamic computing workloads, virtualization and cloud solutions.
HPE ProLiant DL360p Gen8 - Xeon E5-2620 2 GHz - 8 GB - 0 GB
Server - rack-mountable
Height (Rack Units)
1U
EMEA
Server Scalability
2-way
1 x Intel Xeon E5-2620 / 2 GHz ( 2.5 GHz ) ( 6-core )
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
8 GB (installed) / 384 GB (max) - DDR3 SDRAM - 1333 MHz - PC3-10600
Storage Controller
RAID ( SATA 6Gb/s / SAS 6Gb/s ) - PCIe 3.0 x8 ( Smart Array P420i with 1GB FBWC )
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD-RW
Graphics Controller
Matrox G200
GigE
AC 120/230 V ( 50/60 Hz )
Power Redundancy
Optional
43.5 cm x 69.9 cm x 4.3 cm
14.5 kg
3 years warranty - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
EMEA
Processor / Chipset
CPU
Max Turbo Speed
2.5 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 384 GB (max)
DDR3 SDRAM
Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Registered, HP SmartMemory
Configuration Features
2 x 4 GB
RAM Supported
PC3-12800 - 384 GB - registered , PC3-10600 - 768 GB , PC3-10600 - 128 GB - unbuffered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 10, RAID 50
Buffer Size
1 GB
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Integrated
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331FLR
Remote Management Protocol
IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
24 (total) / 22 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x SD card (internal)
1 x serial , 1 x VGA , 4 x LAN (Gigabit Ethernet) , 1 x HP iLO , 6 x USB 2.0 ( 2 front, 4 rear )
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
460 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Certified
SuSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
43.5 cm
69.9 cm
4.3 cm
14.5 kg
10 °C
35 °C
10 - 90% (non-condensing)
