BT.com
Wishlist
HP ProDisplay P202va 19.53" 1920x1080 8ms VGA DisplayPort LED Monitor
Delivery
Standard Due date unavailable
Complement your HP Pro PC with the HP ProDisplay P202va Monitor, a sleek display that delivers essential presentation features and advanced connectivity for your everyday business productivity at a highly affordable price point.
HP ProDisplay P202va - LED monitor - Full HD (1080p) - 19.53"
LED-backlit LCD monitor - 19.53"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2265 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
47.41 cm x 17.59 cm x 35.76 cm
3.3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, WEEE, MEPS, KC, CECP, CEL, TCO Displays, EAC, CEL Grade 1, ISC, SEPA
Display Type
Diagonal Size
19.53"
Viewable Size
19.53"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 96 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Portuguese, Russian, Spanish, Japanese, Korean
HDCP, 72% colour gamut
47.41 cm x 17.59 cm x 35.76 cm - with stand
3.3 kg
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
Stand
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
18.5 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 47.41 cm - depth: 47.41 cm - height: 35.76 cm - weight: 3.3 kg , Without stand - width: 47.41 cm - depth: 5.3 cm - height: 29.21 cm - weight: 2.6 kg
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
