BT.com
Wishlist
HP ProDisplay P202 LED 20" Monitor 1600x900 5MS
Delivery
Standard Due date unavailable
Pair your HP Pro PC with the HP ProDisplay P202 Monitor, a sleek display that delivers essential presentation features and advanced connectivity for your everyday business productivity at a highly affordable price point.
HP ProDisplay P202 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
48.2 cm x 18.66 cm x 35.92 cm
3.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, TCO Displays, EAC, CEL Grade 1, ISC, SEPA
Display Type
Diagonal Size
20"
Viewable Size
20.0"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 70 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Mercury free
48.2 cm x 18.66 cm x 35.92 cm - with stand
3.5 kg
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
Power Supply
Internal
17.8 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 48.2 cm - depth: 18.66 cm - height: 35.92 cm - weight: 3.5 kg , Without stand - width: 48.2 cm - depth: 4.75 cm - height: 35.92 cm - weight: 2.8 kg
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
