BT.com
Wishlist
HP OfficeJet Pro 8740 AIO Colour InkJet MFP
Delivery
Standard Due date unavailable
Maximise your print environment with space-saving HP Print Forward Design and professional-quality, low-cost colour. Help reduce costs with fleet management solutions. Stay productive with an all-in-one designed for high-volume enterprises.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door. Print colour, black & white, and photos – your cost is the same. Ink cartridges and delivery costs included in your monthly plan price. No annual fee – change or cancel plans online anytime without penalty.
Experience revolutionary HP Print Forward Design. Get high speeds for two-sided print and scan jobs with laser-like paper handling, and preserve real estate with space-saving design. Print longer without reloading, with an included second paper tray.
Speed through print jobs, using superfast two-sided printing. Breeze through multipage documents with one-pass two-sided scanning and a 50-page automatic document feeder. Revolutionary design delivers laser-like paper handling and superfast print speeds. Increase paper capacity to 500 sheets with the included second 250-sheet paper tray.
Keep business moving from anywhere in the office. Connect to devices with touch-to-print functionality. Easily print when and where you need to from your smartphone, tablet, or notebook PC.
Print with just a touch of your NFC-enabled mobile device to the printer – no company network needed. Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print from a variety of smartphones and tablets. Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. Expand print capabilities with support for HP PCL 6, HP PCL 5c, and HP PS printing options.
Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts. Easily print Microsoft® Word and PowerPoint® files, plus Adobe® PDF files, directly from your USB drive. Experience a new style of business printing and imaging, with HP JetAdvantage On Demand solutions. Easily take command of your printing environment from one central location, with HP Web Jetadmin.
HP Officejet Pro 8740 All-in-One - multifunction printer (colour)
Fax / copier / printer / scanner
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 37 ppm (mono) / up to 37 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 36 ppm (mono) / up to 36 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
127 x 127 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
500 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, HP ePrint, wireless direct printing, Mopria certified, fax to e-mail, HP Instant Ink
AC 120/230 V (50/60Hz)
55 cm x 53.1 cm x 41.1 cm
18.4 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 2000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF
Automatic Duplexing
First Print Out Time B/W
10 sec
First Print Out Time Colour
11 sec
Colour Management Features
sRGB, Adobe RGB
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Fax Printing Speed
Up to 15 ppm
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
180 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76 x 127 mm
Borderless Photo Sizes
A4 (210 x 297 mm), 215.9 x 279.4 mm
500 sheets
Max Media Capacity
500 sheets
150 sheets
ADF - 50 sheets - 216 x 356 mm , 2 x input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 180 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 24 ppm - B/W (ISO) , Printing: up to 20 ppm - colour (ISO) , Printing: up to 36 ppm - B/W , Printing: up to 36 ppm - colour , Copying: up to 37 ppm - B/W , Copying: up to 37 ppm - colour , Scanning: up to 19 ipm - B/W , Scanning: up to 8 ipm - colour
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, I.R.I.S. OCR, HP Participation Study
35 Watt
Power Consumption Standby
7.2 Watt
Power Consumption Sleep
1.3 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 1000 pages - HP 953 , 1 x Cartridge (cyan) - up to 640 pages - HP 953 , 1 x Cartridge (magenta) - up to 640 pages - HP 953 , 1 x Cartridge (yellow) - up to 640 pages - HP 953
ENERGY STAR Certified
55 cm
53.1 cm
41.1 cm
18.4 kg
Shipping Weight
23 kg
Sound Emission
59 dBA (operating)
15 °C
32 °C
20 - 80%
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Scroll to top
