BT.com
Wishlist
HP Officejet Pro 8600 Plus N911g Colour InkJet e-All-in-One Printer
Delivery
Standard Due date unavailable
HP Office Inkjet All-in-One Printers deliver professional colour and black-and-white documents at a low cost per page, plus a full range of copy and scan tools with advanced paper-handling options.
Print professional documents at up to 50% less cost-per-page than lasers. Equipped with HP ePrint, you can create your own customized email address and print from virtually anywhere with any email-capable device. Also use business apps to access content directly from the web without a PC. It has a low cost-per-page with available high-capacity ink cartridges that offer a better value for frequent printing. It also features a 50-sheet automatic document feeder with 2-sided copy, scan, fax and direct digital filing features such as scan to email, scan to network folder and scan to the web.
Professional color for a lower cost than lasers.
- Print professional color for up to 50% lower cost per page than lasers, and get a better value for frequent printing.[4]
- Print documents that resist fading, water and highlighter-pen smears, using HP Officejet inks.[2][3]
- Achieve ISO print speeds up to 20 ppm black and 16 ppm color,[5] using affordable, individual inks.
- Depend on a printer with a 25,000-page monthly duty cycle--the perfect fit for reliable color printing.
Efficient Web connectivity--even print on the go.[6]
- Print from a variety of mobile devices on the go. With HP ePrint--now you can print from virtually anywhere.[6]
- Use the large touchscreen with gesturing to access business apps, plus quickly print and store files.
- Easily view and print photos from a USB drive and memory cards.
- Stay connected--share on a wireless or wired network.[7]
Standout versatility with copy and scan solutions.
- Create flawless copies with CopySmart solutions, and easily print two-sided identification cards.
- Do more with automatic two-sided print, copy and scan capabilities and the 50-page automatic document feeder.
- Improve workflow--send quick faxes, scan up to legal-size documents to a PC or e-mail, and more.
- Create borderless, double-sided flyers and brochures, plus print impressive business photos.
Exceptional energy and resource savings.
- Use up to 50% less energy than lasers with this ENERGY STAR® qualified printer, and preset On or Off times.
- Easily recycle cartridges, and use up to 70% less supplies and packaging by weight compared with lasers.
- Consume up to 50% less paper while printing, using automatic two-sided printing.
- Use Original HP ink cartridges for quality, reliability and rewards.
[2]Based on paper-industry predictions for acid-free papers and Original HP inks; colorant stability data at room temperature based on similar systems tested per ISO 11798 and ISO 18909.
[3]Based on HP internal testing, using paper with the ColorLok® logo.
[4]Compared with the HP Officejet 950/951 Black and color ink cartridges. For more information, see http://www.hp.com/go/learnaboutsupplies. High-capacity cartridges not included; please purchase separately.
[5]After first set of ISO test pages. For more information, see http://www.hp.com/go/printerclaims.
[6]Requires an Internet connection to the printer. Feature works with any connected Internet- and e-mail-capable device. Print times may vary. Some HP LaserJets may require a firmware upgrade. For a list of supported documents, and image types, see http://www.hp.com/go/eprintcenter. And for additional solutions see http://www.hp.com/go/mobile-printing-solutions.
[7]Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4 GHz routers only. ENERGY STAR® qualified models; see http://www.hp.com/go/energystar
[1] Either after first page or after first set of ISO test pages. For details see http://www.hp.com/go/printerclaims
[2] Power measurements are based on ENERGY STAR® OM test procedure with 230 VAC, 50 Hz input.
[3] Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Actual yield varies considerably based on content of printed pages and other factors. Some ink from included cartridge is used to start up the printer. For details see http://www.hp.com/go/learnaboutsupplies
HP Officejet Pro 8600 Plus e-All-in-One N911g - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
25000 impressions
Recommended Monthly Volume
250 - 1250 pages
Max Copying Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Scanning
4800 x 4800 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from memory card, scan to e-mail, HP ePrint
AC 110/230 V ( 50/60Hz )
49.4 cm x 41.3 cm x 31.5 cm
12.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour - photo
25000 impressions
250 - 1250 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, miniSD, Memory Stick PRO, Memory Stick Duo, SDHC Memory Card, RS-MMC, MultiMediaCardmobile
Copying
Max Copying Speed
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
13 sec
First Print Out Time Colour
14 sec
Scanning
Optical Resolution
4800 x 4800 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Delayed Transmission
Fax forwarding, automatic redialing, answering machine interface, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, delayed sending, fax polling, block fax, save and load speed dials, poll receive, fax activity reports, print fax log
Document & Media Handling
Max Original Size
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 148 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
250 sheets
Max Media Capacity
500 sheets
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 150 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 35 ppm ( A4 ) - B/W draft , Printing: up to 35 ppm ( A4 ) - colour draft , Printing: up to 20 ppm ( A4 ) - B/W (ISO) , Printing: up to 16 ppm ( A4 ) - colour (ISO) , Printing: up to 5 ppm ( A4 ) - B/W best , Printing: up to 3 ppm ( A4 ) - colour best , Copying: up to 35 ppm ( A4 ) - B/W draft , Copying: up to 35 ppm ( A4 ) - colour draft , Copying: up to 13 ppm ( A4 ) - B/W normal , Copying: up to 12 ppm ( A4 ) - colour normal , Copying: up to 3 ppm ( A4 ) - B/W best , Copying: up to 1.5 ppm ( A4 ) - colour best
1 x USB 2.0 , 1 x LAN
Operating System Support
Linux, Apple Mac OS X 10.5, MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7
Software Included
Drivers & Utilities
34 Watt
Power Consumption Standby
6.6 Watt
Power Consumption Sleep
2.2 Watt
Consumables Included
1 x Cartridge ( black ) - up to 1000 pages - HP 950 , 1 x Cartridge ( cyan ) - up to 700 pages - HP 951 , 1 x Cartridge ( magenta ) - up to 700 pages - HP 951 , 1 x Cartridge ( yellow ) - up to 700 pages - HP 951
49.4 cm
41.3 cm
31.5 cm
12.6 kg
Sound Emission
60 dBA (operating)
5 °C
20 - 80%
Accessories
£27.75
£21.25
£21.38
£21.25
HP 950 Black Original Ink Cartridge
Quicklinx: 7PSV | In Stock
£20.08
£54.39
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* HP Officejet Pro 8600 Plus
Reviewed by Kamal on 19/08/2012
This is to replace my HP GX85 which lasted me more than 6 years. It is much faster gives better and clear printouts. It was very easy to setup and I have tested most of its functions and they all work well.I am very pleased with the copier and scanner. An excellent printer.
Scroll to top
