BT.com
Wishlist
HP OfficeJet Pro 6970 MFP
Remakable value for professional, in-office colour!
Delivery
Standard Due date unavailable
Supercharge the office with affordable colour and fast two-sided performance. Save up to 70% on ink with HP Instant Ink, and get a variety of mobile printing options and seamless mobile setup.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Remarkable value for professional, in-office colour
Count on remarkable value for your color printing needs. Spend up to 50% less per page compared with lasers and produce the color and black text output you need to keep your business humming.
Easy mobile printing, seamless mobile setup
Easily print when and where you need to from your smartphone, tablet, or notebook PC. Get up and running right out of the box and connect the way you want to with Ethernet and wireless networking.
Handle more tasks and effortlessly scan
Work quickly and smoothly. Tap and swipe the touchscreen the same way you would a smartphone. Save paper with automatic two-sided printing, copy and scan two-sided originals, and send files to more places with less effort.
HP Officejet Pro 6970 All-in-One - multifunction printer (colour)
Multifunction printer
Fax Type
Plain paper
English / United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
200 - 800 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
212 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to folder
AC 230 V (50/60Hz)
46.37 cm x 39 cm x 22.867 cm
8.1 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
200 - 800 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
1 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
20 station(s)
Broadcast Transmission
Delayed Transmission
Fax forwarding, automatic redialing, auto reduction
Document & Media Handling
Max Original Size
212 x 356 mm
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 88.9 x 127 mm, 101.6 x 127 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
216 x 297 mm
225 sheets
60 sheets
Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 35 sheets - 212 x 356 mm , Output tray - 60 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W draft , Printing: up to 26 ppm (A4) - colour draft , Printing: up to 20 ppm - B/W (ISO) , Printing: up to 11 ppm - B/W (ISO) , Scanning: up to 8 ppm - B/W , Scanning: up to 3.5 ppm - colour , Copying: up to 30 ppm (A4) - B/W draft , Copying: up to 24 ppm (A4) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO)
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
SSL, TLS, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, MS Windows Server 2008 SP1, MS Windows Server 2003 SP1, MS Windows Server 2003 SP2, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
27 Watt
Power Consumption Standby
5.5 Watt
Power Consumption Sleep
1.21 Watt
ENERGY STAR Certified
Limited warranty - 3 years with product registration
46.37 cm
39 cm
22.867 cm
8.1 kg
Shipping Width
50.8 cm
Shipping Depth
28.2 cm
Shipping Height
46.4 cm
Shipping Weight
10 kg
Sound Emission
61 dBA (operating)
15 °C
32 °C
20 - 80% (non-condensing)
Scroll to top
