BT.com
Wishlist
HP Officejet Pro 6830 e-AiO
Delivery
Standard Due date unavailable
Print professional colour documents for business for up to 50% lower cost per page than lasers. This e-all-in-one is designed for productivity with smart features and mobile printing to keep business moving – at work, home or on the go.
HP Officejet Pro 6830 e-All-in-One - multifunction printer (colour)
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
200 - 800 pages
Max Copying Speed
Up to 28 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 29 ppm (mono) / up to 24 ppm (colour)
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
212 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, glossy paper, matte paper
Standard Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
AC 110/230 V (50/60Hz)
46.185 cm x 38.765 cm x 22.4 cm
8 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
15000 pages
200 - 800 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
1 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
14 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
20 stations
Delayed Transmission
Yes (black only)
Fax forwarding, automatic redialing, colour faxing, junk fax barrier
Document & Media Handling
Max Original Size
212 x 356 mm
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 88.9 x 127 mm, 101.6 x 127 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 215 x 355 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
216 x 297 mm
225 sheets
60 sheets
Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 35 sheets - 212 x 356 mm , Output tray - 60 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W (ISO) , Printing: up to 10 ppm (A4) - colour (ISO) , Copying: up to 10 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Scanning: up to 5 ppm - B/W , Scanning: up to 2.8 ppm - colour , Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 24 ppm (A4) - colour draft , Copying: up to 28 ppm (A4) - B/W draft , Copying: up to 24 ppm (A4) - colour draft
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x modem - RJ-11
Operating System Support
Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit
Software Included
Drivers & Utilities
25 Watt
Power Consumption Standby
4.9 Watt
Power Consumption Sleep
1.35 Watt
Ethernet cable
EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, CISPR 22, EMC
ENERGY STAR Certified
46.185 cm
38.765 cm
22.4 cm
8 kg
Shipping Width
50.8 cm
Shipping Depth
28.2 cm
Shipping Height
46.4 cm
Shipping Weight
10 kg
5 °C
20 - 80% (non-condensing)
Accessories
£11.56
Scroll to top
