BT.com
Wishlist
HP OfficeJet Pro 276dw Printer
Delivery
Standard Due date unavailable
Manage your print environment – and budget – with this advanced, network-ready MFP and get up to 50% lower cost per page than lasers. Enjoy easy integration into your office workflow with efficient management and security controls.
Efficiently manage your printing environment—and your budget—with a color MFP that delivers up to 50% lower cost per page than lasers1 and powerful manageability tools. Simplify office tasks with versatile functions and easy networking.
Print for less and easily manage your MFP
  • Print professional-quality color with Original HP inks—for up to 50% lower cost per page than lasers.
  • Easily integrate into your office. Centrally deploy updates and manage tasks with HP Web Jetadmin.
  • Safeguard your print environment with the HP Imaging and Printing Security Center—no expertise necessary.
  • Help protect your investment and extend capabilities as your needs grow with a portfolio of solutions.
Count on versatile features to ease office tasks
  • Ease office workflows. Print, scan, copy, fax, send digital files, and access apps—right from the display.
  • Depend on HP for reliable workgroup printing—designed for volumes up to 1500 pages a month.
  • Reload paper less and handle large print jobs, using the automatic document feeder and 250-sheet paper tray.
  • Print up to 2300 pages—or up to 1500 color pages—from a single high-capacity Original HP cartridge.
Connect and print—at the office or on the go.
  • Add this MFP to your Ethernet or wireless network to easily share with your teammates.
  • Print wirelessly, and share access with PCs, tablets, and mobile devices2—even with no network or router.
  • Print from your smartphone or tablet from virtually anywhere with HP ePrint.
  • Print PDF files and images directly from memory devices, using the easy-access USB port—no computer required.
Conserve resources without sacrificing performance
  • Use up to 50% less energy than lasers—set your printer for savings with Schedule On and Schedule Off.
  • Save up to 50% on paper, using automatic two-sided printing.
  • Use up to 50% less supplies and packaging by weight compared with color laser
HP Officejet Pro 276dw MFP - multifunction printer (colour)
Multifunction printer
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 impressions
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 13 ppm (mono) / up to 12 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 25 ppm (mono) / up to 25 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
4800 x 4800 dpi
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, greeting cards, photo paper, thick paper, card stock, glossy photo paper, matte photo paper, tri-fold paper
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, scan to folder, save to network folder
AC 110/230 V (50/60Hz)
49.4 cm x 46 cm x 31.5 cm
12.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, EPEAT Bronze
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 impressions
250 - 1500 pages
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF
Automatic Duplexing
First Print Out Time B/W
13 sec
First Print Out Time Colour
14 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
4800 x 4800 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
48 stations
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
Borderless Photo Sizes
A4 (210 x 297 mm)
250 sheets
Max Media Capacity
500 sheets
150 sheets
Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) , Output tray - 150 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W draft , Printing: up to 25 ppm (A4) - colour draft , Printing: up to 20 ppm - B/W (ISO) , Printing: up to 15 ppm - colour (ISO) , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 12 ppm - colour (ISO)
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, LEAP, TLS, 802.1x
Operating System Support
Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities, HP ePrint Wireless Direct
35.09 Watt
Power Consumption Standby
7.11 Watt
Power Consumption Sleep
1.63 Watt
ETSI, GOST, RoHS, REACH, LVD
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
49.4 cm
46 cm
31.5 cm
12.7 kg
Shipping Width
56.7 cm
Shipping Depth
38 cm
Shipping Height
52 cm
Shipping Weight
18.2 kg
Sound Emission
62 dBA (operating)
15 °C
30 °C
15 - 80%
Scroll to top
