BT.com
Wishlist
HP Officejet 6700 Premium H711n Colour InkJet e-All-in-One
Delivery
Standard Due date unavailable
HP Officejet 6700 Premium Inkjet e-All-in-One Printer
The HP Officejet 6700 Premium e-All-in-One is designed for micro/small business users looking for an e-all-in-one capable of printing professional, affordable two-sided color via a wired or wireless network or direct from mobile devices.
Get professional quality, two-sided duplex colour printing for a low cost per page with this high productivity premium e-all-in-one inkjet colour multifunction printer. Use the touchscreen control panel to scan, copy, fax, access apps (Requires a wireless access point and an Internet connection to the printer.) and much more. Print on the go or via your wired or wireless network. (Wireless performance is dependent upon physical environment and distance from access point. ) Maximise your productivity and get more done with this versatile premium inkjet e-all-in-one multifunction printer.
Print professional colour documents - single or double-sided - for a low cost per page.
Print professional colour for a low cost per page, and save on frequent printing with high-capacity ink cartridges.[4]
Save time and money - get more done with automatic two-sided printing.
Create vivid, high impact materials that resist water, fading and highlighter-pen smearing with HP Officejet inks.[5],[6]
Enjoy reliable performance from a printer with a 12,000-page monthly duty cycle - ideal for business colour printing.
Maximise your productivity with wired/wireless networking and mobile printing.[2],[3]
Print direct from your mobile device with HP ePrint - now you can print from virtually anywhere.[2]
Share between multiple users across your wireless or Ethernet network, or connect directly using Hi-speed USB.[3]
Print e-mails, documents, web pages and more direct from your iPad®, iPhone® or iPod touch® with AirPrint™.[7]
Manage tasks and access business apps directly on your e-all-in-one via the intuitive touchscreen.
Get more done every day with this versatile e-all-in-one.
Print at ISO (laser comparable) speeds of up to 16 ppm black, 9 ppm colour.
Print and copy without a PC via the touchscreen - use the CopyCrop tool to size and crop documents and photos.
Do more with your time - scan, copy or fax multipage documents using the 35-page automatic document feeder.
Scan documents directly to a PC or USB pen; use the front-facing USB to print documents directly from a USB pen.
[1] Requires a wireless access point and an Internet connection to the printer. Services may require registration. App availability varies by country, language, and agreements. For details, see www.hp.com/go/eprintcenter.
[2] Requires an Internet connection to the printer. Feature works with any connected Internet- and email-capable device. Print times may vary. For a list of supported documents, and image types, see www.hp.com/go/eprintcenter. And for additional solutions, see www.hp.com/go/mobile-printing-solutions
[3] Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4 GHz routers only.
[4] Not included, please purchase separately.
[5] Fade resistance based on paper-industry predictions for acid-free papers and Original HP inks; colorant stability data at room temperature based on similar systems tested per ISO 11798 and ISO 18909.
[6] Water resistance based on HP internal testing, using paper with the ColorLok® logo.
[7] Supports iOS 4.2 and later devices (iPad®, iPhone® 4, iPhone® 3GS, and 3rd and 4th generation iPod touch®) that support multitasking. AirPrint™ and iOS 4.2 and later devices require an 802.11 `wireless network' connection to the printer. AirPrint and the AirPrint Logo are trademarks of Apple® Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
HP Officejet 6700 Premium e-All-in-One H711n - multifunction printer ( colour )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
12000 impressions
Recommended Monthly Volume
200 - 800 pages
Max Copying Speed
Up to 34 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
2.65"
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper, cards, greeting cards, photo paper, thick paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
75 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
HP ePrint
AC 110/230 V ( 50/60Hz )
46.4 cm x 47.6 cm x 25.1 cm
8.77 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
12000 impressions
200 - 800 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
PC Connection
AirPrint Enabled
HP ePrint
Standard Memory
128 MB
Max Supported Memory
128 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time Colour
18 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Fax Resolutions
300 x 300 dpi
Total Memory Capacity
Up to 99 pages
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
20 stations
Delayed Transmission
Yes (black only)
Automatic redialing
Document & Media Handling
Max Original Size
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Borderless Photo Sizes
216 x 297 mm
250 sheets
Max Media Capacity
250 sheets
75 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 75 sheets
Speed Details
Printing: up to 34 ppm - B/W draft , Printing: up to 31 ppm - colour draft , Copying: up to 34 ppm - B/W draft , Copying: up to 31 ppm - colour draft , Printing: up to 16 ppm - B/W (ISO) , Printing: up to 9 ppm - colour (ISO) , Copying: up to 10 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Printing: 17 sec ( 10 x 15 cm (4"x6") ) - photo draft , Scanning: up to 2.8 ppm ( Letter A ) - B/W , Scanning: up to 2.8 ppm ( Letter A ) - colour , Scanning: 23 sec ( 10 x 15 cm (4"x6") ) - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, IPP, SNMP, HTTP, HTTPS, Bonjour, DHCP, BOOTP, NetBIOS
Security Protocols & Features
ARP
Operating System Support
Linux, Apple Mac OS X 10.5, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7
Software Included
Drivers & Utilities
43 Watt
Power Consumption Standby
3.3 Watt
Power Consumption Sleep
3.3 Watt
Limited warranty - 1 year , Technical support - phone consulting
46.4 cm
47.6 cm
25.1 cm
8.77 kg
Shipping Weight
9.9 kg
5 °C
20 - 80% (non-condensing)
Accessories
£24.70
£11.55
£11.55
£11.55
£11.05
Scroll to top
