BT.com
Wishlist
HP NVIDIA Quadro M4000 - Graphics card - Quadro M4000 - 8 GB GD
HP NVIDIA Quadro M4000 - Graphics...
£815.68
27 in stock
£815.68
Add to wishlist
Delivery
Standard 1-3 working days
Create and render large, complex product design and media and entertainment models and datasets by taking advantage of the new Maxwell GPU architecture features in the flexible, single-slot NVIDIA Quadro M4000 graphics card.
Experience ultra-fast visualization and compute horsepower with 8GB ultra-fast GDDR5 memory and 1664 CUDA® parallel processing cores that provide excellent support for accelerated single-precision computing workflows.
With four DisplayPort 1.2 connectors, you can drive up to four 4K displays or two 5k displays. Then easily manage them with included NVIDIA® Mosaic™ and NVIDIA® nView® technologies. Frame-lock multiple displays with the optional NVIDIA® Sync card.
Boost application performance in real time while staying within the power and thermal envelope of the card with NVIDIA® GPU Boost.
Easily support your professional software application base with comprehensive ISV certifications.
Compatible with HP Z440, Z640 and Z840 Workstation series.
NVIDIA Quadro M4000 graphics card - Quadro M4000 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
8 GB GDDR5
CUDA Cores
1664
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Dual-Link): 2560 x 1600 at 60 Hz/ DVI (Single-Link): 1920 x 1200 at 60 Hz/ DisplayPort: 4096 x 2160 at 60 Hz/ VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
4 x DisplayPort , DVI-I (dual link)
API Supported
OpenCL, DirectCompute 5.0, DirectX 12, OpenGL 4.5
24.1 cm x 11.2 cm
Pricing Type
Promo
Workstation Z640
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
CUDA Cores
1664
Max Resolution
4
API Supported
Nvidia 3D Vision technology, Nvidia SLI Mosaic Technology, Multi-Stream Transport, High Bit Rate 2, Nvidia Quadro Warp/Blend, Nvidia Sync
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
192 GBps
Linux, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
120 Watt
24.1 cm
11.2 cm
475 g
Pricing Type
Promo
HP Workstation Z640
HP NVIDIA Quadro M4000 - Graphics card - Quadro M4000 -...
£815.68
Save on this ideal PC Build kit!
Save £8.29
£834.85
Scroll to top
