BT.com
Wishlist
HP NVIDIA Quadro K2200 4GB Graphics Card
Delivery
Standard 1-3 working days
Deliver exceptional power-efficient 3D application performance with the NVIDIA Quadro K2200 graphics card. It's an excellent choice for working with large, complex models in product development and creative content applications.
ISV certifications and solid performance.
Easily support your professional software application base with comprehensive ISV certifications. Enjoy fast performance from 4 GB of GDDR5 GPU memory that allows for fluid manipulation of large models.
Open doors for GPU computing.
Accelerate many CUDA-enabled professional applications with 640 CUDA parallel processing cores and GPU computing in a single slot sub-75W graphics card.
Flexible and easy display management.
Drive ultra-high display resolutions like 4096 x 2160 @ 60 Hz with 30-bit color using a new display engine and DisplayPort 1.2. Easily manage up to three displays with NVIDIA® Mosaic and NVIDIA® nView® technologies.
NVIDIA Quadro K2200 - graphics card - Quadro K2200 - 4 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2200
4 GB GDDR5
CUDA Cores
640
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
3
DVI-I (dual link) , 2 x DisplayPort , DVI - with adapter , VGA - with adapter
API Supported
OpenCL, DirectCompute, DirectX 11.1, OpenGL 4.4
20.2 cm x 11.1 cm
Pricing Type
Promo
Workstation Z240 (MT, tower), Z440, Z640, Z840
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2200
CUDA Cores
640
Max Resolution
3
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, NVIDIA Mosaic, Shader Model 5.0, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-Stream Transport, High Bit Rate 2, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
80 GBps
Linux, Microsoft Windows 7, Windows 8, Windows 8.1
68 Watt
20.2 cm
11.1 cm
300 g
Pricing Type
Promo
HP Workstation Z240 (MT, tower), Z440, Z640, Z840
Scroll to top
