BT.com
Wishlist
HP NVIDIA Quadro K1200 - Graphics card - Quadro K1200 - 4 GB GD
HP NVIDIA Quadro K1200 - Graphics...
£527.94
£527.94
Add to wishlist
Delivery
Standard Due date unavailable
Deliver outstanding professional 3D application performance for product development challenges and media and entertainment creation with the NVIDIA Quadro K1200 low profile plug-in graphics card designed for small form factor HP Z Workstations.
Easily support your professional software application base with comprehensive ISV certifications. Enjoy fast performance from 4 GB of GDDR5 GPU memory that supports large models and data sets.
Drive ultra-high display resolutions like 4096 x 2160 @ 60 Hz with 30-bit color using the integrated display engine and four miniDP connectors. Easily manage up to four displays with NVIDIA® Mosaic and NVIDIA® nView® technologies.
Accelerate single-precision computing workflows with 512 NVIDIA® CUDA® parallel processing cores in a single-slot, low-profile card.
Compatible with the Z240 Worksation Serie.
NVIDIA Quadro K1200 - graphics card - Quadro K1200 - 4 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K1200
4 GB GDDR5
CUDA Cores
512
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Dual-Link): 2560 x 1600 at 60 Hz/ DVI (Single-Link): 1920 x 1200 at 60 Hz/ DisplayPort: 4096 x 2160 at 60 Hz/ VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
4 x Mini DisplayPort
API Supported
OpenCL, DirectCompute 5.0, DirectX 11.1, OpenGL 4.4
17.5 cm x 6.88 cm
Pricing Type
Promo
1 year warranty
Workstation Z230, Z240, Z440, Z640, Z840
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K1200
CUDA Cores
512
Max Resolution
4
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Shader Model 5.0, Multi-Stream Transport, Nvidia Quadro Mosaic Technology, High Bit Rate 2, Maxwell architecture
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
80 GBps
Linux, Microsoft Windows 7 / 8 / 8.1
46 Watt
17.5 cm
6.88 cm
175 g
Pricing Type
Promo
Limited warranty - 1 year
HP Workstation Z230, Z240, Z440, Z640, Z840
Scroll to top
