BT.com
Wishlist
HP LTO4 Ultrium WORM Automation Bar Code Labels (110 pack)
HP LTO4 Ultrium WORM Automation Bar...
£123.38
Hurry, only 1 left in stock!
£123.38
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
HPE LTO Ultrium, Super DLT and DLTtape IV Bar Code Label Packs provide an easy-to-use solution to the aggravation of bar coding. Under constant pressure to deliver quality of service with limited resources, the last thing IT managers should be worrying about is why their in-house bar code labels aren't working properly or whose turn it is to operate (or run) the departmental label printer. Each HPE label pack of consecutively numbered bar codes contains 100 data labels and 10 cleaning cartridge labels. No two pack sequences are ever identical to avoid data integrity issues in archives. HPE Bar Code Label Packs will be available from most resellers that stock HPE brand media. Finally, HPE Bar Code Label Packs have been fully tested to guarantee performance in demanding automation environments, so unlike cheaper alternatives, users can be certain that their backups will never be disrupted by bar code quality issues.
HPE Ultrium 4 WORM Bar Code Label Pack - bar code labels
Bar code labels
HPE MSL2024, MSL4048; 1/8 G2 Tape Autoloader; LTO-4 Ultrium; StorageWorks ESL 712e, MSL2024, MSL4048, MSL6026, MSL8096; StorageWorks 1/8 G2 Tape Autoloader; 1/8 Tape Autoloader; StorageWorks Enterprise Modular Library E-Series 103e; StoreEver Ultrium 1840
Bar code labels
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760 , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE LTO-4 Ultrium 1760 SAS Drive Upgrade Kit, 1760 SCSI Drive Upgrade Kit , HPE StorageWorks ESL 712e, MSL2024 Ultrium 448, MSL4048 Ultrium 448, MSL6026, MSL8096 Ultrium 960 , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 920 , HPE StorageWorks 1/8 Tape Autoloader Ultrium 448, Ultrium 960 , HPE StorageWorks Enterprise Modular Library E-Series 103e Base Library , HPE StoreEver Ultrium 1840 Drive Upgrade Kit
Scroll to top
