BT.com
Wishlist
HP LP2475w 24" Widescreen 1920 x 1200 6ms HDMI 2 x DVI-I LCD Monitor
Delivery
Standard Due date unavailable
HP LP2475w 24 Zoll Widescreen LCD-Monitor
The super-sized HP LP2475w 24-inch Widescreen LCD Monitor offers premier performance and connectivity features in an elegant 24-inch diagonal wide-aspect screen engineered for power users, designers and workstation users who appreciate expansive widescreen presentation of their graphics, video, and data projects.
HP LP2475w - LCD monitor - 24"
LCD monitor - 24"
USB Hub
Panel Type
S-IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Response Time
12 ms (On/Off); 6 ms (grey-to-grey)
Input Connectors
HDMI, 2xDVI-I, DisplayPort, S-Video, composite video, component video
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
55.6 cm x 25.3 cm x 42.2 cm
9.1 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TCO '03, CSA, TUV, VCCI, GS, ISO 13406-2, MIC, FCC, RoHS, WEEE, ACA, CISPR
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB Hub
Panel Type
S-IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Response Time
Vertical Refresh Rate
85 Hz
Horizontal Refresh Rate
94 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Colour Temperature
9300K, 6500K
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature, clock
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
Picture in picture, HDCP, picture outside picture
9.1 kg
2 x DVI-I , 1 x HDMI , 1 x DisplayPort , 1 x component video input , 1 x composite video input , 1 x S-video input , 1 x USB upstream , 6 x USB downstream , SPDIF
Mechanical
Flat Panel Mount Interface
100 x 100 mm
1 x DVI-VGA cable - 1.8 m , 1 x DVI cable - DVI-D to DVI-D - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 2 m , 1 x USB cable - 2 m
Backlight Life
40,000 hours
Power Supply
Internal
75 Watt
Power Consumption Stand by / Sleep
2 Watt
Included Software
Pivot Pro, HP Display Assistant
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80%
Accessories
HP Flat Panel Speaker Bar
Quicklinx: 6KZX | In Stock
£23.98
HP Adjustable Display Stand
Quicklinx: 74K7 | In Stock
£131.19
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* stock levels are irrelevant
Reviewed by JT on 07/11/2010
I'm leaving this review specifically to counter act the toffee brained person who left 1 star because it showed up as being in stock when it wasn't. That is BT fault and has no bearing on how good the product is.
5* Awesome monitor
Reviewed by Anonymous on 25/03/2010
This is a fantastic monitor and is well worth getting. It is great for photoshop and the swivel functionality is great for photoshop.
People giving bad reviews because of stock levels are idiots and the review should be deleted...
4* expensive but worth it
Reviewed by Matt on 16/01/2010
At work we use the very expensive but very good Eizo monitors for print advertising. I wanted something similar but without the price tag. These HP 24" screens are almost as good, in fact the colour and viewing angle tolerance is better, only let down by a slightly uneven backlight.
Recommended to those wishing to experience pro features without the price. I've bought a few of these monitors now.
1* In Stock - Realy ?
Reviewed by Anonymous on 28/11/2009
the in stock is a lie. its not
Scroll to top
