BT.com
Wishlist
HP LE1711 17" 1280 x 1024 5ms VGA LCD Monitor
Delivery
Standard Due date unavailable
HP Compaq LE1711 17-Zoll-LCD-Monitor
Make a positive impact on your business and take advantage of the energy efficient features of HP's Essential series HP Compaq LE1711 monitor, which can help reduce your energy consumption while you grow your business.
HP Compaq LE1711 - LCD monitor - 17"
LCD monitor - 17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Input Connectors
VGA
Display Position Adjustments
Tilt
37.7 cm x 20.6 cm x 38.6 cm
3.9 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
CSA, TUV, VCCI, BSMI, GOST, GS, NOM, SASO, CCC, MIC, FCC, TCO Displays 5.0, ISO 9241-307, ACA, CISPR
Display Type
LCD monitor / TFT active matrix
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Colour Temperature
9300K, 6500K
Controls & Adjustments
Brightness, contrast, sharpness, colour temperature, phase, clock, lens shift dial (horizontal), lens shift dial (vertical)
OSD Languages
Chinese (simplified), English, German, French, Italian, Spanish, Dutch
Anti-glare, anti-static
3.9 kg
VGA
Mechanical
Tilt
Tilt Angle
40
1 x VGA cable - 1.8 m , 1 x power cable - 1.9 m
Backlight Life
50,000 hours
Power Supply
Internal
28 Watt
Power Consumption Stand by / Sleep
2 Watt
EPEAT Compliant
EPEAT Silver
5 °C
35 °C
20 - 80%
Accessories
Accessories
HP Adjustable Dual Monitor Stand
Quicklinx: 7DFG | In Stock
£179.35
Other bundles
HP Quick Relase Bracket for TFT
Quicklinx: 4RPN | In Stock
£25.47
HP Adjustable Display Stand
Quicklinx: 74K7 | In Stock
£130.53
Scroll to top
