BT.com
Wishlist
HP LD5511 55" Class (54.64" viewable) LED display
HP LD5511 55" Class (54.64"...
£1,243.41
£1,243.41
Add to wishlist
Delivery
Standard Due date unavailable
Collaborate and conference in eye-popping style with the HP LD5511 139 cm (55") Large Format Display, which transforms your meeting room into a world-class conference center and delivers exceptional clarity and brilliant colors.
Fantastic front of screen
View content from virtually any corner with the 55" diagonal Full HD screen and 178° viewing angles. High brightness and contrast ratio provide excellent picture quality and readability that’s perfect for meeting rooms that seat up to 12.
Create a complete conferencing solution.
Pair with an HP Elite Slice for Meeting Rooms, HP Collaboration PC with Intel® Unite™ software or HP Chromebox and interact seamlessly with co-workers or clients on an extra-large display that has integrated speakers for crystal clear audio.
Designed for the long haul.
Rest assured with a display that has commercial-grade display components and is ready to run in demanding environments. Best of all, it’s supported by a three-year standard limited warranty and optional HP Care services.
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.64 in
Commercial Use
Yes - digital signage
Country Kits
United Kingdom
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
IPS
LCD Backlight Technology
LED backlight - D-LED Backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
141 Watt
Manufacturer Selling Program
HP Smart Buy
123.86 cm x 32.96 cm x 75.17 cm
17.87 kg
141 Watt
Diagonal Class
55"
Diagonal Size
54.64 in
Commercial Use
TV Tuner
No tuner
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Dimensions
With stand
123.86 cm
32.96 cm
75.17 cm
17.87 kg
Enclosure Colour
HP Smart Buy
Country Kits
United Kingdom
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Display Menu Language
Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 200 mm, 400 x 400 mm
Video Features
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1280 x 720, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1600 x 900
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Network & Internet Multimedia
LAN
Connector Type
VGA input , HDMI , VGA output , DVI-D input , Audio line-in , USB , Network , Audio line-out , Component video input , Remote control input , Remote control output , Audio line-out
VGA cable - 1.8 m , HDMI cable - 1.8 m
Plug and Play, UL, VCCI, C-Tick, BSMI, TUV S, CB, CCC, PSB, FCC, TUV Bauart, EAC, CE/EMC
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Dimensions & Weight Details
Panel without stand - 123.86 cm x 6.17 cm x 71.11 cm x 16 kg
5 °C
20 - 80% (non-condensing)
Scroll to top
