Click to visit BT.com
BT.com
Wishlist
HP LD4200TM TOUCH DIGITAL SIGNAGE DISPLAY
Quicklinx: 79LBWS00
Mfr#: WD017AA
HP LD4200tm 42-inch Widescreen LCD Interactive Digital Signage Display WD017AA
HP LD4200tm 42" LCD flat panel display
LCD flat panel display with touch-screen
220 Watt
Diagonal Class
42"
99.9 cm x 11.9 cm x 59.2 cm - without stand
27 kg
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15), HDMI
HDCP Compatible
Image Aspect Ratio
16:9
TV Tuner
No tuner
Progressive scan
Sound Output Mode
Stereo
Remote Control
Remote control
Microsoft Certification
Compatible with Windows 7
AC 120/230 V ( 50/60 Hz )
3 years warranty
220 Watt
Diagonal Class
42"
Combined with
Touch-screen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15), HDMI
HDCP Compatible
Dimensions
Without stand
99.9 cm
11.9 cm
59.2 cm
27 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
3000:1
Brightness
500 cd/m²
Colour Gamut
72% (NTSC)
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4845 x 0.4845mm
Response Time
9 ms
V-Sync Rate at Max Res.
60 Hz
Max V-Sync Rate
76 Hz
Max H-Sync Rate
83 kHz
Display Menu Language
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese, Korean
Backlight Life
50,000 hour(s)
Progressive scan
Stands & Mounts
Flat Panel Mount Interface
Video Features
Input Video Formats
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Connector Type
1 x VGA input ( 15 PIN HD D-Sub (HD-15) ) , 1 x HDMI input ( 19 pin HDMI Type A ) , 2 x component video input ( BNC x 3 ) , 1 x composite video input ( BNC ) , 1 x S-Video input ( 4 PIN mini-DIN ) , 1 x VGA output ( 15 PIN HD D-Sub (HD-15) ) , 1 x serial , 4 x audio input ( RCA x 2 ) , 1 x audio input ( mini-phone stereo 3.5 mm ) , 1 x composite video output ( BNC )
RoHS, WEEE
Power supply - internal
Nominal Voltage
Power Consumption Stand by / Sleep
1 Watt
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand - 99.9 cm x 11.9 cm x 59.2 cm x 27 kg , Panel with stand - 99.9 cm x 29.3 cm x 66.7 cm x 30.2 kg
