BT.com
Wishlist
HP LaserJet Pro MFP M26a
Delivery
Standard Due date unavailable
Print, scan and copy with the proven reliability of the cheapest compact laser multifunction printer from HP. Get professional results and the performance you expect.
Outstanding reliable quality without compromise
Easily print high-quality documents and with the reliability you expect from the leader in laser printing. Print directly from the start with a pre-installed cassette and an intuitive LED panel. HP Auto-On / Auto-Off technology helps to save energy.
Maximum productivity for business in compact format
Stay productive. Quickly and easily print, scan and copy documents with an efficient, compact laser multifunction printer designed to fit on small workspaces. This multifunction printer from HP provides high-quality results with HP toner cartridges.
Even results that match your work
Provides consistent results that you can trust. You can easily connect to a PC or laptop with USB and start printing. Together with Original HP print cartridges deliver this multifunction printer from HP performance with high quality.
HP LaserJet Pro MFP M26a - multifunction printer (B/W)
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
5000 pages
Recommended Monthly Volume
100 - 1000 pages
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Up to 1200 dpi
Scanning
1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, cards, labels
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
AC 230 V (50/60Hz)
42 cm x 26.6 cm x 25.4 cm
8.3 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
5000 pages
100 - 1000 pages
USB 2.0
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 18 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 1200 dpi
Max Printing Speed
Up to 18 ppm
Printer Drivers / Emulations
TIFF, PCLm, PCLms, JPEG
First Print Out Time B/W
9 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), DL (210 x 99 mm)
150 sheets
100 sheets
Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
255 Watt
Power Consumption Standby
2.2 Watt
Power Consumption Sleep
1.4 Watt
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55022:2010 CISPR 22:2008 Class B, EN 55024:2010
ENERGY STAR Certified
42 cm
26.6 cm
25.4 cm
8.3 kg
Shipping Width
49.7 cm
Shipping Depth
33.2 cm
Shipping Height
35 cm
Shipping Weight
10.3 kg
Sound Emission
47 dBA (operating)
15 °C
32.5 °C
10 - 80%
Scroll to top
