BT.com
Wishlist
HP LaserJet Pro M402dne - printer - monochrome - laser
HP LaserJet Pro M402dne - printer -...
£175.35
3 Year Warranty available!
36 in stock
£175.35
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Printing performance and robust security built for how you work. This capable printer finishes jobs faster and delivers comprehensive security to guard against threats. Original HP Toner cartridges with JetIntelligence give you more pages.
Fast printing. Strong protection.
Shift your office into high gear with a powerful printer that doesn’t keep you waiting. Print your first page and two-sided prints faster than the competition, and help keep your device, data, and documents safe – from boot up to shutdown.
More. Pages, Performance, and Protection.
Print more consistent, high-quality pages than ever before. Specially designed Original HP Toner cartridges with JetIntelligence deliver better performance, higher energy efficiency, and authentic HP quality – which the competition can’t match.
Help save energy and easily manage tasks
Take control of printing – and help save energy. Use a suite of essential features to help you easily manage this power-conserving printer. It’s built to fit right into your office space and work style.
Stay connected with easy mobile printing options
Keep your business nimble when needs shift or opportunity strikes – in the office or on the go. Ethernet capabilities help you stay connected and work with ease – from right where you are.
Printer Type
Workgroup printer - laser - monochrome
8.58 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 38 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 40 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 30 ipm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 32 ipm - B/W duplex (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
4800 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN
AirPrint Enabled
1200 MHz
RAM Installed (Max)
256 MB (256 MB)
Flash Memory Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.7, PCLm, URF, PWG
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, bond paper, recycled paper, light-weight paper, punched paper, preprinted paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Printer Features
HP ePrint, Instant-on Technology, Mopria certified
AC 230V
UNIX, Linux, Red Hat Linux 8.0, Slackware Linux 9.1, Microsoft Windows Vista (32-bit versions), Red Hat Enterprise Linux 5, Microsoft Windows XP SP3, Linux Linpus 9.4, Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Mandriva Linux 2010, Linux Linpus 9.5, Ubuntu 11.10, Ubuntu 12.04, Windows 8 (32/64 bits), openSUSE 12.2, Apple MacOS X 10.8, Red Hat Linux 9.0, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Debian Linux 6.0.7, Apple MacOS X 10.9, Red Hat Fedora 18, Mandriva Linux 2011, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Debian Linux 6.0.5, Ubuntu 14.04, Red Hat Fedora 19, Debian Linux 6.0, Red Hat Enterprise Linux 7, Linux Mint 14, Linux Mint 15, Debian Linux 7.4, Apple MacOS X 10.10, Debian Linux 7.0, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.1 or later, Debian Linux 7.1 or later, PCLinuxOS 2006 or later, Slackware Linux 9.0 or later, gOS
38.1 cm x 35.7 cm x 21.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
4800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
1200 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Flash Memory
Flash Memory
256 MB (installed) / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 197 x 273 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 104.9 x 148.59 mm
Media Weight
60 g/m² - 175 g/m²
350 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
750 - 4000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP
Security Protocols & Features
SSL, Apple Bonjour, TLS, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - up to 3100 pages - HP 26A
Google Cloud Print 2.0
FCC Class B certified, ICES-003, Laser Class 1, FCC CFR47 Part 15, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60825-1:2001, IEC 62479, IEC 60825-1:2007, EN 62479:2010, GB 4943-2011, GB 17625.1-2012, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2013, IEC 60950-1:2005 + A1:2009
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
591 Watt
Power Consumption Stand by
6.1 Watt
Power Consumption Sleep
2.8 Watt
Software Included
Drivers & Utilities
Environmental Standards
Blue Angel
ENERGY STAR
15 °C
32.5 °C
30 - 70% (non-condensing)
Sound Emission (Operating)
54 dBA
38.1 cm
35.7 cm
21.6 cm
8.58 kg
Width (Shipping)
44.3 cm
Depth (Shipping)
27.4 cm
Height (Shipping)
46.4 cm
Weight (Shipping)
11.36 kg
Scroll to top
