BT.com
Wishlist
HP LaserJet Pro M225dn Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
This black-and-white desktop MFP increases productivity with automatic two-sided printing, built-in networking, security features and mobile printing options.
HP LaserJet Pro MFP M225dn - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
500 - 2000 pages
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper, light-weight paper, preprinted paper, postcards
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Bypass Feeder Capacity
10 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, USB host
AirPrint Enabled
Office Machine Features
HP ePrint, Instant-on Technology, Mopria certified
AC 230 V (50/60Hz)
44.25 cm x 28.87 cm x 37.13 cm
11.1 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 pages
500 - 2000 pages
Display
2 lines
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Up to 25 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Collation copy
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
PCL 6, PCL 5c, PDF, PCLm
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
First Print Out Time B/W
8 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 400 pages
PC Faxing
Fax Machine Features
Speed Dialing
120 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 76 x 187 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm)
250 sheets
Max Media Capacity
250 sheets
10 sheets
100 sheets
Input tray - 250 sheets size: 76 x 187 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Bypass tray - 10 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Scanning: up to 15 ppm - B/W , Scanning: up to 6 ppm - colour , Copying: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Copying: up to 25 ppm (A4) , Copying: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Scanning: up to 14 ppm (A4) - B/W normal , Scanning: up to 5 ppm (A4) - colour normal , Printing: up to 15 ipm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
Operating System Support
MS Windows XP SP2 or later, MS Windows 7, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1, Windows 8.1, Apple Mac OS X 10.9, MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits)
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
470 Watt
Power Consumption Standby
4.5 Watt
USB cable, phone cable, Ethernet cable
Consumables Included
1 x Cartridge (black) - up to 1500 pages
FCC Class B certified, CISPR 22 Class B, GS, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN55024:2010, IEC 60950-1:2005, GB 17625.1-2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011
ENERGY STAR Certified
Blue Angel Compliant
44.25 cm
28.87 cm
37.13 cm
11.1 kg
Shipping Width
59.7 cm
Shipping Depth
39.7 cm
Shipping Height
47.8 cm
Shipping Weight
14.4 kg
Sound Emission
50 dBA (operating)
15 °C
32.5 °C
10 - 90%
Accessories
£57.39
Scroll to top
