BT.com
Wishlist
HP LaserJet Pro M130fw Multi-Function Printer
Mobile printing made simple!
Delivery
Standard 1-3 working days
Designed for efficiency
  • Print, scan, copy, and fax (M130fn/fw) with a compact HP LaserJet MFP that fits into tight workspaces.
  • Print up to 22 pages per minute, with first pages ready in as fast as 7.3 seconds.
  • Help save energy with HPAuto-On/Auto-Off Technology.
  • Tackle tasks and scan to email and network folders from the 6.9cm colourt ouchscreen (M130fw).
  • Print from iPhone® and iPad® with AirPrint®, which automatically scales jobs to the correct paper size.
  • Print with the ease of sending an email, right from a smartphone, tablet, or notebook, using HP ePrint.
  • Print directly from your mobile device to your Wi-Fi Direct® printer– without accessing the company network.
  • Send jobs from your smartphone, tablet, or PC to any company printer, using Google Cloud Print™2.0.
HP quality–print after print
  • Produce sharp text, bold blacks, and crisp graphics with precision black toner.
  • Don’t be fooled by alternatives that mimic Original HP. Help ensure you’re getting the quality you paid for.
  • Track toner levels with print gauge technology and produce the most prints possible.
  • Quickly replace your cartridges, using auto seal removal and easy-open packaging.
HP LaserJet Pro MFP M130fw - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
150 - 1500 pages
Max Copying Speed
Up to 22 ppm
Max Copying Resolution
Up to 600 x 400 dpi
Max Printing Speed
Up to 22 ppm
Max Printing Resolution
Up to 1200 dpi
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
148.6 x 210.1 mm (min) - 215.9 x 297.2 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, photo paper, vellum paper, card stock, postcards
Standard Media Capacity
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, HP ePrint, wireless direct printing, Instant-on Technology, Mopria certified, Mobile Printing, HP Auto-On/Auto-Off Technology, JetIntelligence Cartridge Technology, Google Cloud Print 2.0
AC 220 V (50/60Hz)
41.51 cm x 28.8 cm x 27.95 cm
7.6 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
150 - 1500 pages
Display Diagonal Size
2.7"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Up to 22 ppm
Up to 600 x 400 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 1200 dpi
Max Printing Speed
Up to 22 ppm
Printer Drivers / Emulations
PCLms, URF, PWG
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
7.3 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 1000 pages
PC Faxing
Fax Machine Features
Speed Dialing
120 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
Min Original Size
148.6 x 210.1 mm
Max Original Size
215.9 x 297.2 mm
Original Type
Sheets
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm)
150 sheets
Max Media Capacity
150 sheets
100 sheets
Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 22 ppm (A4) - B/W , Copying: up to 22 ppm (A4) - B/W , Scanning: up to 12 ppm (A4) - B/W normal , Scanning: up to 11 ppm (A4) - B/W normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 2 x modem - RJ-11
Operating System Support
Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, HP Device Experience (DXP), HP Web Services Assist
AC 220 V (50/60Hz)
255 Watt
Power Consumption Standby
4.2 Watt
Power Consumption Sleep
1 Watt
USB cable, phone cable
Consumables Included
1 x Cartridge (black) - up to 700 pages , 1 x drum - up to 12000 pages
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:2010, Blue Angel Ecolabel, EN55022:2010 Class B, CISPR 22:2008
ENERGY STAR Certified
41.51 cm
28.8 cm
27.95 cm
7.6 kg
Shipping Width
49 cm
Shipping Depth
32.7 cm
Shipping Height
35 cm
Shipping Weight
10.2 kg
Sound Emission
51 dBA (operating)
15 °C
32.5 °C
10 - 80%
Scroll to top
