BT.com
Wishlist
HP LaserJet Pro M1217nfw Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
HP LaserJet Pro M1217nfw Multifunktionsdrucker
Tackle everyday office tasks with an affordable, full-featured MFP. Plug and print with HP Smart Install. Easily print, copy, scan and fax from one compact machine. Share resources with Ethernet networking or work anywhere with wireless.
HP LaserJet Pro M1217nfw MFP - multifunction printer ( B/W )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser ( monochrome )
Monthly Duty Cycle (max)
8000 impressions
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 600 x 400 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Up to 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Scan to e-mail, scan to application
AC 230 V ( 50/60Hz )
43.5 cm x 26.5 cm x 30.6 cm
8.3 kg
Environmental Standards
ENERGY STAR Qualified , EPEAT Silver
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 impressions
250 - 2000 pages
Display
2 lines x 16 characters
PC Connection
Standard Memory
64 MB
Max Supported Memory
64 MB
Copying
Max Copying Speed
Up to 18 ppm
Up to 600 x 400 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 1200 dpi
Max Printing Speed
Up to 18 ppm
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 dpi
Colour Depth
24 bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Speed Dialing
100 station(s)
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, answering machine interface, junk fax barrier, auto reduction
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), C5 (162 x 229 mm), C6 (114 x 162 mm), 76 x 127 mm
150 sheets
100 sheets
ADF - 35 sheets , Input tray - 150 sheets , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm ( A4 ) - B/W , Copying: up to 18 ppm ( A4 ) - B/W
1 x USB 2.0 ¦ 1 x LAN
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6
Software Included
Readiris Pro
370 Watt
Power Consumption Standby
4.8 Watt
Power Consumption Sleep
2 Watt
USB cable, phone cable
Consumables Included
1 x Cartridge ( black )
EN 61000-3-2, EN55022, IEC 61000-4-11, EN 61000-3-3, EN55024, CISPR 22, EN 300.328, RSS-210, EN 61000-4-4, EN 61000-4-3, EN 61000-4-6, FCC Part 68, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300.489.1, IEC 60825-1, FCC CFR47 Part 15 C, TBR21, EN 60825-1
EPEAT Compliant
EPEAT Silver
43.5 cm
26.5 cm
30.6 cm
8.3 kg
Sound Emission
50 dBA (operating)
10 °C
32.5 °C
10 - 80%
Scroll to top
