BT.com
Wishlist
HP LaserJet Pro 400 M401dn Mono Laser Printer
Delivery
Standard Due date unavailable
Replaces the HP LJ P2055DN
Do more with your workday. Set up anywhere in the office using built-in wireless networking,[5] and share printing resources on a network. Print on the go with mobile printing options. Use business apps to access and print from the Web.
Wireless productivity--impressive mobility
Set up and share anywhere in the office with wireless connectivity.[5] Configure networking fast.[13]
Print from virtually anywhere, using HP ePrint.[6]
Drive productivity and save paper, using automatic two-sided printing.
Boost productivity with fast print speeds.[11] Do more with up to 300-sheet paper capacity.
Web-connected ease of use
Use business apps and the 3.5-inch (8.89 cm) color touchscreen to access and print from the Web.[7]
Install your printer fast--there's no CD required with HP Smart Install.[12]
Use the easy-access USB port to print from--and save scans to--a flash drive.
Easily control your print environment with market-leading management tools.
Professional-quality output for a great value
Produce professional-quality business prints with bold, crisp text and sharp images.
Depend on a printer with a 3000-page recommended monthly page volume--the ideal fit for reliable printing.
Save money by saving energy--HP Auto-On/Auto-Off Technology powers your printer up and down automatically.[8]
Save time with easy-to-install Original HP cartridges, and save more with high-capacity cartridges.[14]
Reduced environmental impact
Reduce energy use with HP Auto-On/Auto-Off Technology.[8]
Reduce paper use by up to 50% with automatic two-sided printing.
Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.[16]
Reduce packaging waste--Original HP toner cartridges ship in the printer.
[1]Available on M401d, M401dn, and M401dw models only.
[2]Available on M401n, M401dn, and M401dw models only.
[3]Available on M401dn and M401dw models only.
[4]Available on M401dw model only.
[5]Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections.
[6]Requires an Internet connection to the printer. Feature works with any connected Internet- and email-capable device. Requires HP Web Services Account Registration. Print times may vary. For a list of supported documents, and image types, see http://www.hp.com/go/eprintcenter. And for additional solutions, see http://www.hp.com/go/mobile-printing-solutions.
[7]Requires a wireless access point and an Internet connection to the printer. Services may require registration. Availability varies by country, language, and agreements, and requires a firmware upgrade. For details, http://www.hp.com/go/eprintcenter.
[8]HP Auto-On/Auto-Off Technology capabilities subject to printer and settings.
[9]Not available on all models. Mobile device must be wireless-enabled. Printer must be HP ePrint-enabled. Feature may require driver or apps, available for download at http://www.hp.com/go/eprintcenter.
[10]Supports the following devices running iOS 4.2 or later: iPad®, iPad® 2, iPhone® (3GS or later), iPod touch® (3rd generation or later). Works with HP's AirPrint-enabled printers and requires the printer be connected to the same network as your iOS device. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint™, the AirPrint Logo, iPad, iPhone, and iPod touch are trademarks of Apple® Inc., registered in the U.S. and other countries.
[11]Measured using ISO/IEC 24734, excludes first set of test documents. For more information see http://www.hp.com/go/printerclaims. Exact speed varies depending on the system configuration, software application, driver, and document complexity.
[12]HP Smart Install works with Windows® only.
[13]HP Auto Wireless Connect may not be available for all system configurations. Wireless performance is dependent upon physical environment and distance from access point. For information on compatibility, visit http://www.hp.com/go/autowirelessconnect.
[14]HP 280X LaserJet Black Toner Cartridge not included; must be purchased separately.
[15]Program features and availability may vary by country. For more information, visit http://www.hp.com/learn/suresupply.
[16]Program availability varies. Original HP cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners program. For more information, or to request return envelopes and bulk collection boxes, visit http://www.hp.com/recycle.
HP LaserJet Pro 400 M401dn - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
11 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 33 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB, Gigabit LAN, USB host
AirPrint Enabled
800 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, cards, recycled paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 3000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Printer Features
HP ePrint
AC 230V
HP-UX 11i, Microsoft Windows XP SP2 or later, Apple MacOS X 10.6, Red Hat Enterprise Linux 5, Apple MacOS X 10.5, Microsoft Windows Server 2003 SP3 or later, Linux Linpus 9.4, Microsoft Windows Vista (32/64 bits), openSUSE 11.3, Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Red Hat Fedora 14, Apple MacOS X 10.7 Lion, Debian Linux 5.x, Debian Linux 6.x, Red Hat Fedora 15, Ubuntu 10.10, openSUSE 11.4, Ubuntu 11.04, Linux Linpus 9.5
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver
1 year warranty
36.46 cm x 36.8 cm x 27.1 cm
Printer Type
Printer
Print Speed
Built-in Devices
Touch screen
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
8 sec
Language Simulation
Printer Features
HP ePrint
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 105 x 148 mm
Media Weight
60 g/m² - 163 g/m²
300 sheets
Max Media Capacity
800 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 3000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2700 pages
Supported Windows 7 Features
Windows Touch
Power supply - internal
AC 230V
Frequency Required
50 Hz
570 Watt
Power Consumption Stand by / Sleep
6.2 Watt
Software Included
HP ePrint
System Requirements Details
Windows 7/Vista - 1 GHz - RAM 1 GB - HD 400 MB , Windows XP SP2 - Pentium - 233 MHz - RAM 512 MB - HD 400 MB , MacOS X 10.5/10.6/10.7 - PowerPC G4 HD 500 MB
EPEAT Compliant
EPEAT Silver
ENERGY STAR
Limited warranty - 1 year
30 - 70%
36.46 cm
36.8 cm
27.1 cm
11 kg
Accessories
£94.65
£163.45
£293.26
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Deeply awful installation process. Doesn't work.
Reviewed by M Power on 28/06/2014
I chose this product after my previous HP printer died. It had been fine for several years. This one was chosen because I wanted the Wi-fi connectivity. HP's own software will not recognise the printer as WiFi enabled. I tried the up to date drivers from their website and the ones on the CD provided. Hopeless. The installation guide is a waste of time and bears no resemblance to what actually happens when you try to install this large black useless piece of plastic. It will print via USB but the whole point was to be able to print from other devices as we as my desktop. Unfortunately BT make it clear they advise you contact the manufacturer before them if the item is faulty, which is wrong as the contract is between the vendor and buyer so they should deal with it. I have wasted a lot of time on this. Badly disappointed. I will avoid HP in the future and BT because of not taking responsibility for what they sell. Been a loyal BT customer for many years. Shame.
Our response
Hi Michael, We recommended speaking to HP to ensure you can do fault diagnostic to check if they can help first, quite often they can and the issue is resolved. If that doesn't work then please contact our CS teams who will process and RMA. Thanks Dunc
Scroll to top
