BT.com
Wishlist
HP LaserJet P2035 Mono Laser Printer
HP LaserJet P2035 Mono Laser...
£161.07
1 on order, delivery delayed
£161.07
Add to wishlist
Delivery
Standard Due date unavailable
HP LaserJet P2035 Printer
HP LaserJet P2035 - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
9.9 kg
English / United Kingdom
Max Media Size (Standard)
Legal
Print Speed
Up to 30 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution ( B&W )
1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Parallel, USB
266 MHz
RAM Installed ( Max )
16 MB ( 16 MB )
Language Simulation
PCL 5E
Media Type
Envelopes, transparencies, labels, plain paper, glossy paper, cards
Total Media Capacity
300 sheets
Monthly Duty Cycle (max)
25000 pages
AC 120 V
UNIX, Novell NetWare, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.4.3, Microsoft Windows Vista, Apple MacOS X 10.5.x
Microsoft Certification
Certified for Windows Vista
1 year warranty
36.6 cm x 36.8 cm x 25.7 cm
Printer Type
Printer
Print Speed
Wired
Parallel, USB
1200 dpi
PostScript Support
Standard
First Print Out Time B/W
8 sec
Language Simulation
PCL 5E
Fonts Included
45 x TrueType
266 MHz
RAM
16 MB / 16 MB (max)
Media Handling
Media Type
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm)
300 sheets
Media Feeder(s)
1 x autoload - 50 sheets - Legal (216 x 356 mm) , 1 x autoload - 250 sheets - Legal (216 x 356 mm)
Output Trays Capacity
150 sheets
Duty Cycle
25000 pages
1 x USB 2.0 , 1 x parallel
Consumables Included
1 x toner cartridge ( black )
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, UL, cUL, EN 61000-3-2, GS, ICES-003, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
Power supply - internal
AC 220 to 240 V
Frequency Required
50 Hz
550 Watt
Power Consumption Stand by / Sleep
7 Watt
Software Included
Drivers & Utilities
1 year warranty
Service & Support Details
Limited warranty - 1 year - on-site - response time: next business day
17.5 °C
25 °C
30 - 70%
36.6 cm
36.8 cm
25.7 cm
9.9 kg
Accessories
£140.77
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 5CCP 035650
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£66.82
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
