Click to visit BT.com
BT.com
Wishlist
HP Laserjet MFP Analog Fax 300 Accessory
HP LaserJet MFP Analog Fax Accessory 300
Quicklinx: 3JZ8WS00
Mfr#: Q3701A#ABU
Type: component
£238.86
Easily send and receive documents by adding embedded analog fax functionality to your HP LaserJet MFP. Eliminate the need for a standalone analog fax with seamless integration on HP Color LaserJet 9500mfp, LaserJet 9040/9050mfp, and LaserJet 4345mfp.
HP Analog Fax Accessory 300 - fax interface card
Fax interface card
English / United Kingdom
Max Fax Transfer Rate
33.6 Kbps
Color LaserJet CM4730 MFP, CM4730f MFP, CM4730fm MFP, CM4730fsk MFP; LaserJet 4345mfp, 4345x mfp, 4345xm mfp, 4345xs mfp, M5025 MFP
Fax interface card
Modem
Wired
33.6 Kbps
HP Color LaserJet CM4730 MFP, CM4730f MFP, CM4730fm MFP, CM4730fsk MFP , HP LaserJet 4345mfp, 4345x mfp, 4345xm mfp, 4345xs mfp, M5025 MFP
HP Laserjet MFP Analog Fax 300 Accessory             Bundle deal on HP Laserjet MFP Analog Fax 300 Accessory
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£248.85
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£242.95
saving £0.88
Type: component
Brand: HP
Price Range Inc VAT: 150 - 300
