BT.com
Wishlist
HP LaserJet M5025 Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
Fulfill workteam A3 printing and copying needs and provide scan-to-email from your MFP plus optional fax functionality, with a tool that is affordable and easy to use and makes processes simple and efficient.
HP LaserJet M5025 MFP - multifunction printer (B/W)
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
200000 impressions
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
76 x 127 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
312 x 470 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper
Standard Media Capacity
600 sheets
Max Media Capacity
2100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Optional (copying)
Connection Availability
USB 2.0, LAN
61 cm x 57.1 cm x 58.4 cm
55 kg
Microsoft Certification
Certified for Windows Vista
Copier Type
Digital
Printing Technology
Laser - monochrome
200000 impressions
USB 2.0, LAN
Standard Memory
256 MB
Max Supported Memory
512 MB
Hard Disk Drive
40 GB
Copying
Max Copying Speed
Up to 25 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
1000
Automatic Duplexing
Optional
Printing
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF 1.4
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
First Print Out Time B/W
10 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
105 g/m²
Supported Media Type
600 sheets
Max Media Capacity
2100 sheets
100 sheets
250 sheets
Bypass tray - 100 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 364 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 120 g/m² , ADF - 50 sheets size: 138 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 105 g/m² , Output tray - 250 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m²
Speed Details
Printing: up to 25 ppm - B/W , Copying: up to 25 ppm - B/W
1 x USB 2.0 , 1 x LAN
Network Protocols
IPX/SPX, AppleTalk, DLC/LLC
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple MacOS X 10.2 or later, MS Windows XP Professional x64 Edition, Apple Mac OS X 10.3.9, Apple MacOS X 10.4 or later
Software Included
Drivers & Utilities
1265 Watt
Power Consumption Standby
24 Watt
Power Consumption Sleep
0.1 Watt
Consumables Included
1 x Cartridge (black) - up to 15000 pages
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, cUL, EN 61000-3-2, ICES-003, NOM, EN 61000-3-3, EN55022 Class A, CISPR 22, FCC Part 68, FCC CFR47 Part 15, UL 60950-1, CSA C22.2 No. 60950-1-03
61 cm
57.1 cm
58.4 cm
55 kg
Shipping Width
85.2 cm
Shipping Depth
76.6 cm
Shipping Height
72.1 cm
Shipping Weight
61.1 kg
15 °C
35 °C
20 - 80%
Accessories
£186.44
Scroll to top
