BT.com
Wishlist
HP LaserJet Enterprise M4555fskm Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
Increase productivity with this MFP's fast print and copy speeds, an HP Easy Select control panel and outstanding paper-handling features. Use market-leading management tools to integrate the MFP into existing printing environments.
HP LaserJet Enterprise M4555fskm MFP - multifunction printer (B/W)
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
250000 impressions
Recommended Monthly Volume
5000 - 20000 pages
Max Copying Speed
Up to 52 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 52 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning
600 dpi
Display
8.07"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper
Standard Media Capacity
2100 sheets
Max Media Capacity
2100 sheets
Output Trays Capacity
900 sheets
Stacker
Included
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50Hz)
102 cm x 71 cm x 112 cm
87.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
250000 impressions
5000 - 20000 pages
Display Diagonal Size
8.07"
Display Features
Touch screen
Standard Memory
1280 MB
Max Supported Memory
1280 MB
Copying
Max Copying Speed
Up to 52 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Up to 52 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
First Print Out Time B/W
9.5 sec
Scanning
Optical Resolution
600 dpi
Colour Depth
30-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm)
2100 sheets
Max Media Capacity
2100 sheets
900 sheets
ADF - 50 sheets - A4 (210 x 297 mm) , 3-bin mailbox - 900 sheets , 4 x input tray - 500 sheets - A4 (210 x 297 mm) , Input tray - 100 sheets - A4 (210 x 297 mm)
Speed Details
Printing: up to 52 ppm (A4) - B/W , Copying: up to 52 ppm (A4) - B/W
Finishing Equipment
Stacker
Included
Stapler
Included
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
IPP
Security Protocols & Features
Kerberos, SSL, TLS, IPsec
Operating System Support
MS Windows Server 2003, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later
Software Included
Drivers & Utilities
AC 230 V (50Hz)
1024 Watt
Power Consumption Standby
54 Watt
Power Consumption Sleep
21.6 Watt
Phone cable
Consumables Included
1 x Cartridge (black)
EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1
ENERGY STAR Certified
102 cm
71 cm
112 cm
87.5 kg
Shipping Width
85.6 cm
Shipping Depth
76 cm
Shipping Height
172 cm
Shipping Weight
109.3 kg
Sound Emission
57 dBA (operating)
10 °C
30 °C
10 - 80%
Accessories
£263.94
£158.62
£472.72
Scroll to top
