BT.com
Wishlist
HP LaserJet Enterprise Flow M630h Colour Laser Multifunction Printer
Delivery
Standard Due date unavailable
Rely on a full-featured HP Enterprise Flow MFP that streamlines digital workflow with advanced HP Flow solutions, safeguards business data and documents with a robust suite of top-flight security features and offers simple, efficient mobile printing.
HP LaserJet Enterprise Flow MFP M630h - multifunction printer (B/W)
Printer / copier / scanner
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
250000 pages
Recommended Monthly Volume
5000 - 28000 pages
Max Copying Speed
Up to 57 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 57 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
68 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper
Standard Media Capacity
600 sheets
Max Media Capacity
3100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, HP ePrint, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), pull-out keyboard
AC 230 V (50Hz)
73.7 cm x 64.3 cm x 57 cm
51.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1 year warranty
Printing Technology
Laser - monochrome
250000 pages
5000 - 28000 pages
Display Diagonal Size
8"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
2 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 57 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Up to 57 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
68 x 148 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 216 x 356 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
600 sheets
Max Media Capacity
3100 sheets
100 sheets
500 sheets
ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 57 ppm (A4) - B/W normal , Copying: up to 57 ppm (A4) - B/W normal , Scanning: up to 60 ppm (A4) - B/W normal , Scanning: up to 45 ppm (A4) - colour normal , Scanning: up to 60 ipm (A4) - B/W duplex , Scanning: up to 44 ipm (A4) - colour duplex , Printing: up to 39 ppm (A4) - B/W duplex , Printing: up to 60 ppm (Letter A) - B/W normal , Copying: up to 60 ppm (Letter A) - B/W normal , Copying: up to 41 ppm (Letter A) - B/W duplex , Copying: up to 39 ppm (A4) - B/W duplex , Printing: up to 41 ipm (Letter A) - B/W duplex , Printing: up to 39 ipm (A4) - B/W duplex , Scanning: up to 60 ppm (Letter A) - B/W duplex , Scanning: up to 45 ppm (Letter A) - colour duplex , Scanning: up to 60 ipm (Letter A) - B/W duplex , Scanning: up to 45 ipm (Letter A) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
Kerberos, LDAP, SSL, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
Sun Solaris 8, Sun Solaris 9, MS Windows 7, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2
Software Included
Drivers & Utilities, HP Web Jetadmin
AC 230 V (50Hz)
970 Watt
Power Consumption Sleep
6.5 Watt
First Copy Out Time B/W
7.5 sec
FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EMC, Laser Class 1, FCC CFR47 Part 15, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60825-1:2001, IEC 62479, IEC 60825-1:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, EN55024:2010, IEC 60950-1:2005, EN55022:2010 Class A
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site
73.7 cm
64.3 cm
57 cm
51.6 kg
Shipping Width
78.3 cm
Shipping Depth
75.5 cm
Shipping Height
73.6 cm
Shipping Weight
62.36 kg
Sound Emission
26 dBA (idle) / 61 dBA (operating)
15 °C
32.5 °C
10 - 80%
Scroll to top
